Gcode to extrude 100 mm of filament
The new for 2016 Rostock MAX v3!
taggedzi
Postby taggedzi » Sat Oct 20, 2018 9:53 pm
My printer is no where close to a computer and I'm REALLY hoping to not have to move it... again. Is there a gcode file I can generate to get it to extrude 100 mm of filament for calibration? I tried a few I found on line and looking around, but so far whenever I try it does nothing. I have disconnected the bowden tube and heated up the hot end to 180, but still no dice. I figure this should be simple I just don't seem to know.
The printer is working (except not well calibrated). It has been out of use for about 3 months and moved a good bit. I wanted to re-calibrate and start printing again.
Thanks in advance.
taggedzi
Rostock MAX v3
Not all who wander are lost.
MrWiggum
Re: Gcode to extrude 100 mm of filament
Postby MrWiggum » Mon Nov 05, 2018 1:14 pm
Any software such as matter control connected to the printer should be able to extrude the 100mm. I use octoprint and I have to heat up to 200 in order to start extruding and octoprint has an option to just extrude if wanted.
Return to “Rostock MAX v3”
Who is online
Users browsing this forum: No registered users and 0 guests
