What are the benefits of upgrading my Rostock Max V3 to a V3.2
The new for 2016 Rostock MAX v3!
Cpaclee
Postby Cpaclee » Sun Jul 08, 2018 12:04 am
Hey guys, I love my Max V3, have printed hundreds of hours on it. Should I upgrade to the V3.2 and what are the benefits of it?
Iamarobot
Re: What are the benefits of upgrading my Rostock Max V3 to a V3.2
Postby Iamarobot » Wed Aug 01, 2018 4:59 am
Anyone have a respoonse? I'm thinking about upgrading to 3.2 as it looks like my heater cartridge is shot in my HE280, but want to know for sure that it's a worthwhile upgrade and would allow printing higher temperature materials reliably.
ULTIMATE 3D JEDDI
Postby geneb » Wed Aug 01, 2018 7:50 am
The largest benefit to the upgrade is the 32 bit Duet controller. You'll get excellent calibration, every time. You can also do rapid moves at 400mm/sec without losing steps.
Iamarobot
Postby Iamarobot » Wed Aug 01, 2018 2:21 pm
Thanks, geneb.
Any experience with the SE300 vs. the HE280 in terms of high temperature materials? Or is there a clearly better solution like an E3D V6?
Bogative
Postby Bogative » Sat Aug 11, 2018 12:33 am
Iamarobot wrote:Anyone have a respoonse? I'm thinking about upgrading to 3.2 as it looks like my heater cartridge is shot in my HE280, but want to know for sure that it's a worthwhile upgrade and would allow printing higher temperature materials reliably.
I am wondering the same thing with mine.. It can not hold temp once it hits layer 2 and the fans come on. Slowly drifts down and I tried redoing PID cal. I also tried doing PID cal with fans on but never got to temp. Assume heater cartridge.. Cheap enough to get new one and test but was also considering the upgrade if I could find a good reason.
Iamarobot
Postby Iamarobot » Sat Aug 11, 2018 1:19 am
I went ahead and got the upgrade kit, and am doing a first test print now. So far, it is insanely much quieter and seems to handle speed better. The Duet browser control has a lot of nice features and information, and the calibration is much more thorough.
Did I mention how much quieter it is?
I have to set up Cura so that I can really put it through its paces this weekend and next week, but so far so good. I was using Mattercontrol with the V3, which was fine, but I do prefer Cura.
Check your 12AWG power wires into the Rambo board - I had loose wires into the board which I think is what started my issues with hot end temperature stability. I don't know if that led to a fried heater cartridge, or if it was coincidental to that problem, but when I checked one of the wires just fell out of the terminal block.
Bogative
Postby Bogative » Wed Aug 15, 2018 7:45 pm
Iamarobot wrote:I went ahead and got the upgrade kit, and am doing a first test print now. So far, it is insanely much quieter and seems to handle speed better. The Duet browser control has a lot of nice features and information, and the calibration is much more thorough.
Sounds good.. I don't want to spend the $600 right now as I would have to add touchscreen controller as well. Noise is a non-issue for my location. Ordered 2 heater carts but I will check the wiring when I get back in town. I would like to get it back in service my Prusas have been running almost non-stop so I need another printer going.
MrWiggum
Postby MrWiggum » Mon Nov 05, 2018 1:07 pm
Could you upgrade v3 to v3.2 without the duet and keep printing using the board that came with the v3?
ULTIMATE 3D JEDDI
Postby geneb » Tue Nov 06, 2018 9:01 am
Without the Duet board, you're not upgrading, you're just swapping out hot ends - to one that the RAMBo can't use for auto-calibration.
MrWiggum
Postby MrWiggum » Wed Nov 07, 2018 1:15 pm
Good to know, thank you, that means it's time to buy the bundle :D :D
ULTIMATE 3D JEDDI
Postby geneb » Thu Nov 08, 2018 7:44 am
You won't regret it. The auto-calibration is nearly witchcraft-level good and watching a Rostock MAX rapid move at 400mm/sec is something to see. ;)
MrWiggum
Postby MrWiggum » Thu Nov 08, 2018 11:33 am
400mm that's insane, scary insane, can't wait to see it. Any guides should I follow when calibrating the new 3.2 update?
ULTIMATE 3D JEDDI
Postby geneb » Fri Nov 09, 2018 8:09 am
The docs should cover it, but you basically hit the calibrate button and it'll do its thing. ;)
Return to “Rostock MAX v3”
Who is online
Users browsing this forum: No registered users and 0 guests
