Motor brand
A place for anything else electronics related
adarcher
Motor brand
Postby adarcher » Sun Jan 29, 2017 6:40 pm
Not sure if this is the correct forum, but I'm looking for how to identify my motors. They have no labels on them. I bought my V2 about in Oct 2015. I got the ballcup arms in the kit, but also an ATX powersupply.
I've also got some other unmarked motors. Are there serial numbers hidden somewhere, possibly inside? I don't mind opening them up, but I don't want to unless I have to.
Re: Motor brand
Postby Xenocrates » Sun Jan 29, 2017 10:24 pm
They are likely from Automation technology. In most cases, somewhere on the outer casing there will be a model number. However, if I am recalling correctly, they have stickers rather than engraved serial numbers or model numbers. I believe they are KL17H247-168-4A motors. As for other unmarked motor's, your best bet is to try to characterize them rather than trying to find internal model numbers, as to a large extent, the numbers are intended to make inventory control or replacement easier, and having to open a motor doesn't serve either purpose. You can always try though.
Rostock Max V2, 760W corsair modular PSU, PT100 enabled E3D V6 and volcano, self adjusting carriages, Raymond style enclosure
adarcher
Re: Motor brand
Postby adarcher » Mon Jan 30, 2017 1:38 am
I actually found a sticker on the bottom of the bottom plate :O
You were right about the Automation Tech inc.
KL17H248-15-4A
DeltaCon
Re: Motor brand
Postby DeltaCon » Mon Jan 30, 2017 2:51 am
I once wanted to find my motor specifics. I stuck my phone in the base an shot about 50 pictures in different positions until I found one with the label on it ;-)
Rostock V2 / E3D V6 / Raymond Style Heatchamber on the way!
Return to “OTHER Electronics”
Who is online
