Azteeg X3 Pro Configuration.h
ULTIMATE 3D JEDDI
Postby mhackney » Thu Aug 14, 2014 7:14 pm
Attached is my Repetier 0.91 Configuration.h file for folks to use as an example.
Keep in mind a couple of key points:
  • I have an original Rostock with 15 tooth pulleys so you need to change that to 20 teeth if needed.
  • The PID tuning for the hot end and bed will need to be calibrated for YOUR system. I run a 4 hot end Kraken but only have 1 extruder configured in this example to keep it simple.
  • I run my Onyx on 24 volts on an SSR.
  • I have the Viki display configured
  • I'm using thermistor 1 (rather than 0) for my hot end because I blew my T0 port
  • I have my X3 Pro setup for 32 micro steps, so adjust appropriately if you do not
  • of course, calibration is unique to my machine, you'll have to use your calibration parameters or recalibrate
Configuration.h
(53.41 KiB) Downloaded 295 times
Cheers,
Renha
Re: Azteeg X3 Pro Configuration.h
Postby Renha » Fri Aug 15, 2014 1:33 am
what about buttons on ViKi? I have done configuration my own, and they are unlogical and impossible to use, have you done some configuration of buttons?
3D printing is magic!
ULTIMATE 3D JEDDI
Postby mhackney » Fri Aug 15, 2014 6:20 am
Not yet, I typically print using a host PC/Mac so haven't spent much time on this. The default Viki screens work fine for my needs. What did you have in mind?
cheers,
Renha
Postby Renha » Fri Aug 15, 2014 6:37 am
mhackney wrote:The default Viki screens work fine for my needs. What did you have in mind?
I don't know how to do anything except homing all steppers. Cursor doesn't move down, instead when I press buttons screen getting clear or change screen to another, only center button does what it should.
ULTIMATE 3D JEDDI
Postby mhackney » Fri Aug 15, 2014 8:43 am
The dial on the Viki is a little funky. The inner part with the bumps rotates and "clicks" (its a button). The larger outer ring has 4 "buttons" at N, S, E, W. Mine doesn't really do anything with these so I don't use them. These are probably what you are talking about?
zack4200
Postby zack4200 » Sun Feb 08, 2015 11:21 pm
My uncle and I are in the process of upgrading his V2 Rostock with an Azteeg x3 and the Kraken, so I used your Configuration.h file. When I try to compile the firmware, I get this error.
This report would have more information with
"Show verbose output during compilation"
enabled in File > Preferences.
Arduino: 1.0.6 (Windows NT (unknown)), Board: "Arduino Mega 2560 or Mega ADK"
In file included from BlinkM.cpp:5:
Marlin.h:225: error: 'EXTRUDERS' was not declared in this scope
Marlin.h:226: error: 'EXTRUDERS' was not declared in this scope
Marlin.h:227: error: 'EXTRUDERS' was not declared in this scope
Marlin.h:228: error: 'NUM_AXIS' was not declared in this scope
I was wondering if you have any input as to what I could do to fix this. We're both trying to learn more about 3d printing, and my Google-fu doesn't seem to be up to par right now.
Renha
Postby Renha » Mon Feb 09, 2015 12:46 pm
You could try mine, based on 0.92 version. Current settings are for 2 extruders. https://github.com/Renha/Repetier-Firmw ... e/settings
ULTIMATE 3D JEDDI
Postby mhackney » Fri Feb 13, 2015 7:32 pm
It looks like you are using Marlin firmware so not much of the Repetier configuration is going to help.
Return to “Azteeg X3 and X3 Pro”
Who is online
Users browsing this forum: No registered users and 0 guests
