Config file for Repetier firmware builder
The RAMBo board is finally here, and here's a place to talk about it!
ULTIMATE 3D JEDDI
Postby Jimustanguitar » Fri Dec 05, 2014 4:26 pm
Has anyone created a config file for using Repetier's firmware builder on the website? I'd love to play around with V.092 and keep up with the more current revisions.
http://www.repetier.com/firmware/v092/index.html
I'm currently running "stock" Rambo electronics, and would love to have a starting point to jump off of.
briankb
Re: Config file for Repetier firmware builder
Postby briankb » Sun Jan 18, 2015 10:42 pm
I second this request.
Nylocke
ULTIMATE 3D JEDDI
Postby Nylocke » Thu Feb 05, 2015 3:18 pm
I posted one in my build log. You'll need to scroll down a bit viewtopic.php?f=42&t=6446&start=175
Let me know if anything needs changed
Nylocke
ULTIMATE 3D JEDDI
Postby Nylocke » Tue Feb 17, 2015 6:35 pm
Known working config file. Just rename to configuration.h
Configuration-2.h
(23.98 KiB) Downloaded 131 times
Jrjones
Postby Jrjones » Wed May 20, 2015 9:57 pm
How do you set the Z height with v0.92.3 ? I swear I saw it briefly in the LCD menu, but can't find it anymore.
I've got it set via the EEPROM but its far easier to adjust it via the LCD.
ULTIMATE 3D JEDDI
Postby Jimustanguitar » Thu May 21, 2015 8:14 am
Jrjones wrote:How do you set the Z height with v0.92.3 ? I swear I saw it briefly in the LCD menu, but can't find it anymore.
Not sure about which exact version I'm running, but on mine it's: click, scroll to advanced settings at the bottom, click, scroll to set z height at the bottom.
So go to the bottom of the menu list, two layers deep, and you'll find it there.
Jrjones
Postby Jrjones » Thu May 21, 2015 2:48 pm
Ah, I got it.
I had changed the Z_HOME_DIR to 0 because I thought it was making the carriages move up into the limit switches after homing. But it also turns off the Z Calibration menu if its set to zero.
Return to “RAMBo”
Who is online
