Orion Repair Manual
Hank106
Orion Repair Manual
Postby Hank106 » Thu Aug 14, 2014 9:18 pm
Is there a manual available for typical repairs the Orion requires? Even just an assembly manual would be helpful for disassembling to fix something.
ULTIMATE 3D JEDDI
Re: Orion Repair Manual
Postby Eaglezsoar » Thu Nov 27, 2014 12:07 pm
Hank106 wrote:Is there a manual available for typical repairs the Orion requires? Even just an assembly manual would be helpful for disassembling to fix something.
There is the Orion Users Manual V2 located here: viewtopic.php?f=65&t=4186
ULTIMATE 3D JEDDI
Postby geneb » Thu Nov 27, 2014 1:04 pm
That's the user's manual Eagle, not an assembly manual.
ULTIMATE 3D JEDDI
Postby Eaglezsoar » Thu Nov 27, 2014 2:26 pm
geneb wrote:That's the user's manual Eagle, not an assembly manual.
Thank you, now fixed.
rurwin
Postby rurwin » Tue Jan 03, 2017 6:58 pm
Since there isn't a repair manual, would it be possible to put together a post describing the differences between the Orion and the Max V3? It doesn't need excruciating detail, just notes on how they are similar and different. They both use Rambos, but are the extruder and the hot-end the same? If not, what are they called so we can look up the specs and details ourselves. That sort of thing.
ULTIMATE 3D JEDDI
Postby Jimustanguitar » Wed Jan 04, 2017 2:01 am
They'll both have the same control board, steppers, extruder, carriages, etc. The main difference right now (aside from the build volume), and one that I'm sure will be updated soon, is the accelerometer board and the new hotend. An Orion today does not have those parts, as far as I know. Aside from the HE280 assembly, they're pretty much the same machine in two different sizes. There are some assembly and cosmetic differences, but they have almost identical component and feature lists.
rurwin
Postby rurwin » Wed Jan 04, 2017 2:28 am
Thanks. That's exactly what I wanted.
Return to “ORION Official Docs”
Who is online
Users browsing this forum: No registered users and 2 guests
