Vapor bath
thenewguy
Vapor bath
Post by thenewguy » Thu Sep 05, 2013 11:41 am
Has anyone else done this recently? I like the results!
Before
Cooking
After
Installed
ULTIMATE 3D JEDDI
Re: Vapor bath
Post by geneb » Thu Sep 05, 2013 11:45 am
How long did you leave it in there? What bed temp?
thenewguy
Re: Vapor bath
Post by thenewguy » Thu Sep 05, 2013 12:04 pm
geneb wrote:How long did you leave it in there? What bed temp?
2 hours at 110 with very little acetone. (Was my first time)
When I bumped it up to 115 with a few table spoons of acetone it really kicked in. I think I had to heat up the glass jar a bit more. Which is why I did the 5c bump.
The key is to have it vape and then cool at the top of the jar and drip back down to the bottom.
cope413
Re: Vapor bath
Post by cope413 » Thu Sep 05, 2013 1:48 pm
I do it often.
I use a glass 20 gallon aquarium
I use one of these...
http://www.amazon.com/Aroma-AHP-303-Single-Plate-Black/dp/B0007QCRNU/ref=sr_1_1?ie=UTF8&qid=1378403086&sr=8-1&keywords=heating+plate
I put acetone in a little foil bowl on the plate.
I like to hang the parts from the lid with surgical tubing and alligator clips.
Bring the acetone to a rolling boil and it really fills the space with vapor rapidly.
3-5 minutes is all you need to really get a good smoothing effect. More than that and you can weaken the part significantly.
The parts need to dry/re-harden for 15-20 minutes, but they look great.
Flateric
Re: Vapor bath
Post by Flateric » Fri Sep 06, 2013 5:31 am
I use the identical jar you have used (Walmart) except I put a rubber silicon bead around it to keep in the vapor much longer.
ULTIMATE 3D JEDDI
Re: Vapor bath
Post by Eaglezsoar » Fri Sep 06, 2013 11:10 am
cope413 wrote:I do it often.
Do you remember the temperature required to get the acetone to boil?
cope413
Re: Vapor bath
Post by cope413 » Fri Sep 06, 2013 1:12 pm
It's very low. My hotplate doesn't have temp readings, just 1-10 settings.
I believe it's in the neighborhood of 120-130F, but it has very high vapor pressure, so it doesn't take much above room temp for it to begin vaporizing.
The nice thing about it is that even though it boils at a low temp, it won't ignite until it gets to 400+F. You can really fill the chamber up quick, which makes for nice, smooth, and evenly bathed parts.
Flateric
Re: Vapor bath
Post by Flateric » Fri Sep 06, 2013 6:11 pm
Just wanted to clarify here. You are referring to flash point and not vapor ignition point. The vapor will easily ignite at room temperature and the vapor is extremely flammable. And source of ignition at all will easily ignite the vapor even from a open vessel at room temp.
It will not flash (self ignite) until the temps you mention.
Important differences for those that may have felt it was not a fire hazard until high temps. It most definitely is.
cope413
Re: Vapor bath
Post by cope413 » Fri Sep 06, 2013 8:59 pm
Ah, yes, probably good to clarify that. In a closed tank without much oxygen, the risk of fire is minimized, but it is indeed extremely volatile and flammable.
thenewguy
Re: Vapor bath
Post by thenewguy » Sat Sep 07, 2013 1:04 am
Flateric wrote:I use the identical jar you have used (Walmart) except I put a rubber silicon bead around it to keep in the vapor much longer.
Sounds good to me! I need to find some round glass that will fit inside for a flat surface. Also need to rig something up to lift the platform out when I'm done... Hmmmmm
Flateric
Re: Vapor bath
Post by Flateric » Sat Sep 07, 2013 2:03 am
I'm sorry I was far to busy staring at your avatar to hear a word you said.
thenewguy
Re: Vapor bath
Post by thenewguy » Sat Sep 07, 2013 4:02 am
Haha of course you can't hear me. I tried printing this lady on the 6th
Getting excited...
What a tease she was.... : ( I think I need a glue stick this time.
dbkarmann@live.com
Re: Vapor bath
Post by dbkarmann@live.com » Sat Sep 07, 2013 7:52 am
can i get the file for the lady I would like to try and print it
thank you
Flateric
Re: Vapor bath
Post by Flateric » Sat Sep 07, 2013 8:13 am
You should have stopped while you were "a-head" short of the end.
They are less trouble that way too, LOL.
ULTIMATE 3D JEDDI
Re: Vapor bath
Post by Eaglezsoar » Sat Sep 07, 2013 9:47 am
dbkarmann@live.com wrote:can i get the file for the lady I would like to try and print it
thank you
I agree, can we get the file for the lady?
Found it: http://www.makershop.co/shop/fantasygra ... panther-v2
thenewguy
Re: Vapor bath
Post by thenewguy » Sat Sep 07, 2013 7:49 pm
I have been away from my printer to try it again. I'm going to try round two Sunday afternoon. So post your results guys!
My lady will need a bath for sure when I'm done with her. Haha
thenewguy
Re: Vapor bath
Post by thenewguy » Sun Sep 08, 2013 7:29 pm
Got it. : )
Front
Back
Does anyone know how to get rid of all the little bumps when it starts the layers. I use kiss and not 100% sure with how the settings affect my prints.
dbkarmann@live.com
Re: Vapor bath
Post by dbkarmann@live.com » Mon Sep 09, 2013 7:36 am
Thank you eaglezsoar!
