Rostock MAX v2 Print not smooth
mraybon
Post by mraybon » Sat Jul 20, 2019 10:27 am
Hi,
I am looking a little advice be for I start taking my printer apart. Had the max v2 for 5 years and allays print fine . but lately I have started getting these lines and cant figure it out, dose it on all prints and with difference slicer. Hopeing someone can point me in a direction or a link. tried searching but don't know what to call it.
thanks so much to everyone.
see pic
https://drive.google.com/file/d/1Hq47aq ... sp=sharing
ULTIMATE 3D JEDDI
Re: Rostock MAX v2 Print not smooth
Post by geneb » Sun Jul 21, 2019 9:56 am
You might want to check to make sure there's no debris on the belts or in the belt path.
mraybon
Post by mraybon » Tue Jul 30, 2019 2:29 pm
Thanks g.
I checked the belts and belt path. Adjusted the belts and still get the same print.
Is there any thing else that might be causing this?
Thanks for your help I am going crazy trying to fix this.
ULTIMATE 3D JEDDI
Post by geneb » Wed Jul 31, 2019 7:31 am
Are you using the original arms on your v2? If so, can you post a pic of the arm end?
tnx.
mraybon
Post by mraybon » Wed Jul 31, 2019 11:58 am
These are the pictures.
Thanks for your help.
ULTIMATE 3D JEDDI
Post by Mac The Knife » Thu Aug 01, 2019 7:35 am
Motor pulley setscrews starting to come loose maybe?
ULTIMATE 3D JEDDI
Post by geneb » Thu Aug 01, 2019 8:36 am
I would check to make sure that the carriages are still tight on the rails. I've had two v2s that have had broken screw pockets, primarily due to my inadvertent over-tightening of the screws. :)
mraybon
Post by mraybon » Sun Aug 04, 2019 9:07 pm
OK I checked the carriage, its good belt are tight. used MatterControl and Cura 4.0, Printed in PLA and ABS (the light blue one). Any more suggestion or am I just stuck with this as the best it going to get?
Thanks for all the help so far.
ULTIMATE 3D JEDDI
Post by geneb » Mon Aug 05, 2019 9:31 am
You might want to send an email to support and send them a link to the thread.
Return to “Rostock MAX v2”
