Need a Free SOLIDWORKS Trial?
http://solidworks.com
Jackie625
Post by Jackie625 » Tue Mar 19, 2019 11:59 am
Want to take SOLIDWORKS for a test drive?
Click the link below and learn how to start your free trial
[mod note: Fisher Unitech is a SolidWorks reseller, so this is basically spam.]
www.fisherunitech.com/blog/get-solidworks-free-trial
ULTIMATE 3D JEDDI
Re: Need a Free SOLIDWORKS Trial?
Post by Mac The Knife » Wed Mar 20, 2019 8:22 am
i use Solidworks at work, but I have my own subscription of Fusion 360. I can't see see spending $4,000.00 for solidworks, when I get way more out of Fusion 360 for only $310.00 a year.
ULTIMATE 3D JEDDI
Post by geneb » Wed Mar 20, 2019 8:27 am
If you're a veteran, you can get SolidWorks incredibly cheaply (if memory serves, under $100). However, spammy resellers probably don't want you to know that kind of thing. :)
ULTIMATE 3D JEDDI
Post by Mac The Knife » Wed Mar 20, 2019 10:52 am
The CAM that's built into Fusion 360 works pretty well.
ULTIMATE 3D JEDDI
Post by geneb » Thu Mar 21, 2019 8:16 am
I abhor the idea of renting software. :)
For a great stand-alone CAM program, you should take a peek at EstlCAM. I discovered it during my research into building an MPCNC machine (which is /finally/ built).
ULTIMATE 3D JEDDI
Post by Mac The Knife » Thu Mar 21, 2019 10:26 am
In my library of CAM, I have SheetCAM, MeshCAM, and V-Carve. The CAM portion of Fusion360 really kicks it up several notches with the tool libraries, and the adaptive machining. Watching it rough out a pocket in aluminum, using a 1/4" endmill, with a depth of cut set at 1/4" is amazing. I did have my hand over the E-Stop button the first couple of times.
Return to “SolidWorks”
