xnaron
Postby xnaron » Tue Apr 23, 2013 11:45 pm
After seeing the awesome Berrybot3D by Werner Berry I got magnet fever and had to have one. I did not have the time to cnc mill and lathe the required parts out of metal so I decided to see if I could make a printable part set. Well I did and it worked better than I could have ever hoped. I'd like to share it with the community so they can benefit from it. Please find the details below. Don't hesitate to post any questions you have in this thread. The details below are a work in progress and I will continue updating them as required.
STL's:
https://github.com/xnaron/Xnaron-Magnarms-for-Rostock (openscad files to be uploaded in due course)
Parts:
- Magnets http://shop.revolutionmachines.com/3-8- ... 8-12pc.htm (BE CAREFUL NOT TO LET THE MAGNETS SNAP TOGETHER AND NEVER USE PLIERS ON THEM. THEY ARE FRAGILE AND CAN EASILY BREAK)
- Balls http://www.ebay.com/itm/380140413083
- Alum or carbon fiber tube x 6 @ exactly 240mm long
- 12 x 3mmx6mm cap head allen screws to be jb welded to the balls. Important: Clean the balls and the screws in an acetone bath before gluing.
- JB Weld (Mix it well)
- Assorted 3mm screws, washers and locknuts to mount the components
- CA glue
Optional Parts:
- Squirrel cage fans for cooling PLA. http://www.ebay.com/itm/180389680237
- os1r1s squirrel fan mount https://github.com/os1r1s-/misc-parts
Instructions/notes:
- Use a small dab of jb weld to glue the 3mmx6mm screw to the ball. I use one of the boom ends with the magnet in it in a vice to hold the ball. The magnet will help suck the screw down when you are gluing it. Let it cure under a lamp about 12" from the bulb.
- Use a 3mm washer under every ball on the effector and the cheapskate mounts.
- Use 3mm cap head screws to secure the cheapskate ball mounts to the cheapskate carriages.
- Use a longer 3mm screw to cut the threads for the balls in the effector and cheapskate ball mounts. Don't try and thread with the ball
- Use CA to glue the ball ends to the tubes if you don't have a push fit (don't forget to put the magnets in). Make sure all the arms are the same length.
- make sure you use 3/8" outer diameter tubes for the arms cut to exactly 240mm. This will match the firmware #define DELTA_DIAGONAL_ROD 269.0 // mm in configuration.h
- You need to #define END_EFFECTOR_HORIZONTAL_OFFSET 36.5 in configuration.h for the new effector. (if you don't do this you prints will be too large)
- The stock seemecnc hot end will work in this but don't use the standoffs. You want to keep the hotend away from the printed effector.
- I used 1/4" light ply to laser cut the all the dxfs EXCEPT for the J-Head groove mount which is thinner material.
BOWDEN Extruder:
- This bowden extruder derived from tscdan's excellent design.
- Files on my github
- Uses same ptfe pushfit that are on SeeMeCNC Rmax.
- Stepper Kysan 1040222 http://www.kysanelectronics.com/Product ... ordID=8318
- Gear on stepper from Stock Drive products. Part number: s10t05m022s0508 https://sdp-si.com/eStore/Catalog
- I am getting 60mm/s retracts with Rambo current set to 115. It is ultra quiet.
Flateric
Re: Printable magnetic u-joint option for Rostock Max
Postby Flateric » Wed Apr 24, 2013 12:57 am
Very nice!
Are the files up anywhere?
xnaron
Postby xnaron » Wed Apr 24, 2013 11:04 am
Flateric wrote:Very nice!
Thanks. I will put them up after I run the first test which should be very soon. Stay tuned. :)
xnaron
Postby xnaron » Wed Apr 24, 2013 8:09 pm
Need to verify the geometry is correct in the firmware but it works great!
Flateric
Postby Flateric » Wed Apr 24, 2013 11:19 pm
Looks good, I wouldn't be too concerned about geometry if you have verified arm length, mounting position of balls.
I'd love to have a go at those files soon! LOL
Is holding power fairly decent? Think that it could support a dual hotend setup?
jesse
Postby jesse » Thu Apr 25, 2013 12:41 pm
Nice, I'm interested in trying it.
cambo3d
ULTIMATE 3D JEDDI
Postby cambo3d » Thu Apr 25, 2013 4:29 pm
looks nice, I'm going to mill some mounts out of 1/8" aluminum to try out, similiar to the berry bot but based on the seemecnc plateform.
xnaron
Postby xnaron » Thu Apr 25, 2013 10:29 pm
I'll release the files soon guys. I just want to get it printing first. this should happen this weekend.
I calibrated the bed to within 1/1000". The left tower needs a slight adjustment but the other 3 positions are dead on.
aerouta
Postby aerouta » Fri Apr 26, 2013 12:49 pm
nice
xnaron
Postby xnaron » Fri Apr 26, 2013 7:00 pm
First print in progress
xnaron
Postby xnaron » Fri Apr 26, 2013 8:20 pm
and the results
xnaron
Postby xnaron » Fri Apr 26, 2013 9:20 pm
Here is the first try on the pyramid.
xnaron
Postby xnaron » Sat Apr 27, 2013 12:15 am
Some pics
elqisqeyano
Postby elqisqeyano » Sat Apr 27, 2013 3:32 am
xnaron wrote:I'll release the files soon guys. I just want to get it printing first. this should happen this weekend.
We need those files. I have been pondering this same idea, your a genius man. An affordable upgrade to the Rostock Max.
Thanks a bunch.
Flateric
Postby Flateric » Sat Apr 27, 2013 4:18 am
xnaron wrote:Some pics
That last print sample is mouth watering its so nice.
Testing over, time for public beta test! LOL
Files......files......files.....Can you tell I am anxious for them.
Oh ya, one more thing....
FILES!
ApacheXMD
Postby ApacheXMD » Sat Apr 27, 2013 4:21 am
Xnaron, so you had to drill new holes in the cheapskates to mount your printed pieces, right?
The print results look amazing!
xnaron
Postby xnaron » Sat Apr 27, 2013 8:28 am
ApacheXMD wrote:Xnaron, so you had to drill new holes in the cheapskates to mount your printed pieces, right?
No I used 3mm screws in the existing holes. I used the outside holes rather then the inside ones.
xnaron
Postby xnaron » Sat Apr 27, 2013 8:32 am
Yeah I think that is arguably the best print I have ever made on any of my printers.
aerouta
Postby aerouta » Sat Apr 27, 2013 10:46 am
Nice print! Looks like those joints are working out. I think your hot end also as a lot to do with the quality of the prints you are getting.
Can you post a link to that last file you printed? I would like to give that a shot soon. Also I am assuming you are using KISS?
Are the following features on or off:
Z-lift
wipe
jitter
retract
xnaron
Postby xnaron » Sat Apr 27, 2013 11:08 am
aerouta wrote:Nice print! Looks like those joints are working out. I think your hot end also as a lot to do with the quality of the prints you are getting.
Z-lift
wipe
jitter
retract
Its the Vica Illusion Sculpture here http://www.thingiverse.com/thing:5700
zlift 0.05 (artifact of previous config. I should turn it off. 0.05mm doesn't really do anything as it is so small.)
Prime/Suck/Wipe 5/5/5
jitter 0
It does have a lot to do with the hot end. I couldn't get retraction working properly with PLA on the stock hot end. I'm running the J-Head with the 0.5mm nozzle.
xnaron
Postby xnaron » Sat Apr 27, 2013 11:12 am
Thanks a bunch.
Thanks! I'm writing up an article on my blog with details and I'll have the files up when I'm done.
bvandiepenbos
Postby bvandiepenbos » Sun Apr 28, 2013 12:05 am
Nice work on the printable magnetic joints. Great design.
truenorthtrader
Postby truenorthtrader » Sun Apr 28, 2013 11:14 pm
OMG that's amazing the print results speak for itself I didn't even think that was possible to get such good quality
xnaron
Postby xnaron » Sun Apr 28, 2013 11:39 pm
Thanks guys! I am am extremely happy with this setup. I've made a number of prints now and they all come out incredibly beautiful.
Here is an earlier video.
elqisqeyano
Postby elqisqeyano » Mon Apr 29, 2013 12:10 am
xnaron wrote:Thanks guys! I am am extremely happy with this setup. I've made a number of prints now and they all come out incredibly beautiful.
Files up yet?
Return to “Rostock MAX”
Who is online
Users browsing this forum: No registered users and 9 guests
