Motor brand
A place for anything else electronics related
adarcher
Motor brand
Postby adarcher » Sun Jan 29, 2017 6:40 pm
Not sure if this is the correct forum, but I'm looking for how to identify my motors. They have no labels on them. I bought my V2 about in Oct 2015. I got the ballcup arms in the kit, but also an ATX powersupply.
I've also got some other unmarked motors. Are there serial numbers hidden somewhere, possibly inside? I don't mind opening them up, but I don't want to unless I have to.
ULTIMATE 3D JEDDI
Re: Motor brand
Postby Xenocrates » Sun Jan 29, 2017 10:24 pm
They are likely from Automation technology. In most cases, somewhere on the outer casing there will be a model number. However, if I am recalling correctly, they have stickers rather than engraved serial numbers or model numbers. I believe they are KL17H247-168-4A motors. As for other unmarked motor's, your best bet is to try to characterize them rather than trying to find internal model numbers, as to a large extent, the numbers are intended to make inventory control or replacement easier, and having to open a motor doesn't serve either purpose. You can always try though.
adarcher
Re: Motor brand
Postby adarcher » Mon Jan 30, 2017 1:38 am
I actually found a sticker on the bottom of the bottom plate :O
You were right about the Automation Tech inc.
KL17H248-15-4A
DeltaCon
Re: Motor brand
Postby DeltaCon » Mon Jan 30, 2017 2:51 am
I once wanted to find my motor specifics. I stuck my phone in the base an shot about 50 pictures in different positions until I found one with the label on it ;-)
Rostock V2 / E3D V6 / Raymond Style Heatchamber on the way!
Return to “OTHER Electronics”
Who is online
