Silly Idea: new CNC archtecture
rurwin
Post by rurwin » Tue Jan 10, 2017 7:12 pm
It struck me today that one could arrange a CNC machine, although not a 3D printer, to have only a single axle/runner for all three axes.
There are two arms that rotate. The X arm holds the work-piece and the Y arm holds the effector. The effector incorporates the Z axis. Routers and such only need a limited vertical movement which is easy to arrange on a single track with a belt-feed. The arm axles do not move vertically and do not revolve the full 360 degrees and so can be well braced .
It would of course need new maths in the firmware and be almost as complex to control as a delta, while taking up more space than a cartesian. It would be damn cool to watch though.
Eric
Re: Silly Idea: new CNC archtecture
Post by Eric » Tue Jan 10, 2017 8:05 pm
And if you make sure the effector can reach to the center of the X axis, then the entire X platter becomes a build surface.
Here's your idea in action, using both X and Y rotation: http://www.youtube.com/watch?v=tNpsFQ_VqJ0
Search for "Polar 3d printer" to find some other designs, although most of them only rotate around either X or Y, not both. They exist and are workable, but haven't gone mainstream like Delta's have.
rurwin
Post by rurwin » Wed Jan 11, 2017 3:12 am
There's nothing new under the sun.
I would guess though that the reason it hasn't gone mainstream is that getting Z axis movement to the extent required for 3D printing is somewhat tricky. But routing and drawing require much less Z axis length, probably less than an inch, and laser-cutting needs none.
barry99705
Post by barry99705 » Wed Jan 11, 2017 7:41 am
This one is more fun to watch, though youtube's antishake is really screwing with the video in a couple places!
https://www.youtube.com/watch?v=O93z18w5SNU
ULTIMATE 3D JEDDI
Post by Jimustanguitar » Wed Jan 11, 2017 8:40 am
I always liked the way that these machines moved.
https://www.youtube.com/watch?v=9d0anWb ... e=youtu.be
ULTIMATE 3D JEDDI
Post by mhackney » Wed Jan 11, 2017 8:45 am
One other (big) reason why this design hasn't gone mainstream is because resolution decreases the further you go from the center. Unlike a Cartesian geometry where resolution is identical over the entire build volume. For milling this is important, for 3D printing it could probably be accommodated in the machine design but then that would require much higher resolution steppers/drivers, etc, adding to cost. The delta geometry suffers from the same issue of resolution decreasing as you go out from the center but it is much smaller decrease due to the trigonometry.
rurwin
Post by rurwin » Wed Jan 11, 2017 1:42 pm
@Jimustanguitar, that is beautiful.
@mhackney, I can see that, yes, but if I am interesting in an A4 surface and only sub-milimetre precision, not microns, a geared and/or micro-stepped stepper should be well up for the job. For an 8'x4' size or for precision milling the situation may be different.
On a 12" diameter circle, a 0.9 degree resolution is just under a tenth of an inch. So you would need to boost that a bit, but only by maybe ten or twenty times for many applications. You should still get a responsive machine with that amount of gearing.
IMBoring25
Post by IMBoring25 » Wed Jan 11, 2017 1:59 pm
I had envisioned something similar to use the Y axis as a spring-loaded tool changer.
Return to “The Lounge”
