When does the Eris enter production?
The ERIS Delta, a truly affordable entry into Delta 3D Printing
ULTIMATE 3D JEDDI
Re: When does the Eris enter production?
Post by Mac The Knife » Mon May 02, 2016 7:47 pm
Will it be using the stock, SeeMeCNC nozzles?
PartDaddy
Post by PartDaddy » Tue May 03, 2016 8:39 am
Our HE280 is a new design using a single 30mm blower and single heating resistor. The accelerometer is under the blower. The blower blows up. The valve can be turned to control air flow part either on or off. The intake of the blower pulls air across the heat sink to cool the hot end.
HE280 Eris Hot End by SeeMeCNC MAY 2016
~PartDaddy
SeeMeCNC Owner & Founder
Since 1996
AlanZ
Post by AlanZ » Tue May 03, 2016 9:16 am
Is it possible to mount the new hot end assembly below the effector plate?
The main reason I have my current hot ends below the plate is to make the nozzle more visible to a time lapse camera. It also generally makes it easier to remove stray filaments wit forceps, without having the effector, ball ends and arms so close to the nozzle.
The gains of having a sensor may very well outweigh these other advantages.
PartDaddy
Post by PartDaddy » Tue May 03, 2016 9:18 am
you'd have to make an adapter, we haven't done that
~PartDaddy
Since 1996
AlanZ
Post by AlanZ » Tue May 03, 2016 9:24 am
I added a few notes to my previous post.
I would be happy to make an adapter, if you don't see any reason that one would not work.
Thanks for your insights.
ULTIMATE 3D JEDDI
Post by Xenocrates » Tue May 03, 2016 11:12 am
Will you guy's be publishing the board size soon? I would like to figure out what sort of mount would be needed to get it working with an E3D (No slight intended towards you guy's hotends, but with the sunk costs of my hotend set, and the desire to keep PT100's, I'm not planning to use the new one with it (I may work with getting the old stock one to play nice with it)). Presuming of course that you make the board available separately from the hotend.
PartDaddy
Post by PartDaddy » Tue May 03, 2016 8:08 pm
Here you go. 8-) This is literally work I just finished today. Have fun, happy hacking.
https://github.com/seemecnc/eris_delta/ ... 0hot%20end
Note the push to connect is not in there. It's pressed in john guest PTC fitting. The circuit board and components are perfect because they are the actual part files used to make everything. Also, all of these Solidworks files are 100% accurate to the current production model. Note the tiny height difference under the No.4 sheet metal screws. This is to pinch the circuit board firmly in place. We are making the very last mold tomorrow. Nathan will be machining the middle section of the blower ducting. The first fully functional Eris will be running Friday (what could possibly go wrong?).
BTW, we will machine another aluminum heat sink for groove mounting our new hot end.
~PartDaddy
Since 1996
ULTIMATE 3D JEDDI
Post by Mac The Knife » Tue May 03, 2016 8:53 pm
And Y'all are going on vacation on Monday?
johnoly99
Post by johnoly99 » Fri May 06, 2016 9:14 am
Hah! Mac. Vacation? Not so much, well not monday ;) Steve's headed out next week to drive the PartDaddy and the Eris machines out to the Bay Area MakerFaire, JJ and I are flying out on the 18th, then i'm driving back with the trailer, and JJ is flying back the following monday. Plenty of work left to do, like, the DropLit v2 drops next week too :)
ULTIMATE 3D JEDDI
Post by Mac The Knife » Wed May 11, 2016 9:14 am
"Out for Delivery" WOOT!!!!
ULTIMATE 3D JEDDI
Post by Mac The Knife » Wed May 11, 2016 11:50 am
BINGO!!
AlanZ
Post by AlanZ » Wed May 11, 2016 12:05 pm
Ooooh, a box with a handle... now that's good design!
Mine won't get here until later this week, it's still in transit.
ULTIMATE 3D JEDDI
Post by Mac The Knife » Wed May 11, 2016 12:15 pm
I'll have plenty of visitors in my work area today!
ULTIMATE 3D JEDDI
Post by Mac The Knife » Thu May 25, 2017 10:33 pm
So I'm dredging this one up from a year ago. I have # 32. A year has gone by and I'm curious what has changed with the Eris production? What sort of running changes have been made?
Return to “ERIS Delta”
