Issue with z height?
The ERIS Delta, a truly affordable entry into Delta 3D Printing
Matt Gunn
Postby Matt Gunn » Fri Sep 16, 2016 4:23 pm
Hi, I have just started using my Eris. I have a Rostock V2 as well. After my first two prints (the calibration box and a small camera mount for a quadcopter) the Eris z height raised so the PLA barely lays down on the glass. I have run the calibration multiple times but it doesnt seem to help. Should I just increase the z_max in the eprom by .1mm until its better? Or is there another issue/fix?
bvandiepenbos
Re: Issue with z height?
Postby bvandiepenbos » Fri Sep 16, 2016 7:27 pm
You should be probing with it cold.
Matt Gunn
Postby Matt Gunn » Sat Sep 17, 2016 9:05 am
I was.
Matt Gunn
Postby Matt Gunn » Sun Sep 18, 2016 6:16 pm
Does anybody have any ideas why this has happened?
KAS
ULTIMATE 3D JEDDI
Postby KAS » Sun Sep 18, 2016 6:31 pm
what slicer and can you post a sample gcode?
Return to “ERIS Delta”
Who is online
