Raspberry Pi 3 Mount for Eris
The ERIS Delta, a truly affordable entry into Delta 3D Printing
sgraber
Postby sgraber » Fri Sep 02, 2016 9:47 am
I thought I'd throw this snap-on bracket out there for the group in case anyone is wanting to run their Eris with OctoPrint:
http://repables.com/r/787/
Mount your Pi to it and snap it on the back tower and you're good-to-go. Photos: https://goo.gl/photos/sGec9TcXQrDWDMfT7
Thank you to Oly for the original mount!
626Pilot
ULTIMATE 3D JEDDI
Re: Raspberry Pi 3 Mount for Eris
Postby 626Pilot » Sat Sep 03, 2016 3:47 am
That's a really nice design. How are you faring with the autolevel feature?
sgraber
Postby sgraber » Sat Sep 03, 2016 7:53 am
Auto-leveling seems to work OK. I tend to run it after every print since I am removing the build platform and it doesn't get put back into the exact same orientation every time. Pretty easy if you are using Mattercontrol or Octoprint.
djkirkendall
Postby djkirkendall » Sun Mar 12, 2017 12:34 am
This mount is awesome, thanks for working it up and sharing it.
I wound up stealing power from the "Eris" LED up front. Plenty of Juice to run the pi. I soldered in a parallel line from the circuit board.
Return to “ERIS Delta”
Who is online
