How to set up two Z axis limit switches in Droplit?
Troubleshooting topics around resin based printing
Andradez
Postby Andradez » Thu Jul 30, 2015 3:42 pm
Hello All, I assembled a Droplit machine some months ago and i recently got another resin (3DInk Orange) to test with the Droplit.
I was able to print a small toy figure that ended up like the pictures on the link below:
https://photos.google.com/share/AF1QipOzd27REc1lFh4vyVgPDZg_LJI56yY2pMOQS7RMXps2ddOKozqeBLUpb_KZXVdJvg?key=UUZmajlQRno2T2tMaDB3MTRQQmZ1N3V4WEJoazln
The problem is that i need to have 2 limit switches/end stops because the platform already broke 2 glass plates for going below the VAT/glass
plate level causing a unbelievable mess.
Sometimes, when i use Creation Workshop and try to move the Z-axis up, it goes down instead and does not stop so it keeps going down until it brakes the VAT/glass
and the carriage reaches the bottom and it cannot go further. Out of panic i turned the machine off but after inspection there was some dents left in the melamine from the force
of the motor/platform hitting the bottom where the carriage stopped.
So, you can see this kind of problem is very prejudicial.
My problem is:
I have the upper limit switch installed and working but i cannot figure out which pins to use to install a lower limit switch in
the GSHIELD V5 board.
I have two wires for the upper limit soldered at positions : GND and D11 in GSHIELD V5.
Should i connect the lower limit switch wires in the same positions as the upper limit ones?
I appreciate help from anyone who has experience with this kind of problem.
Thank you
Andradez
Who is online
Users browsing this forum: Bing [Bot] and 1 guest
