Makerjuice G+
Resins, sources, hybrid mixes, made-at-home and more
johnoly99
Makerjuice G+
Postby johnoly99 » Thu Aug 07, 2014 9:07 am
Been testing more with the G+ formula from makerjuice, and so far the red, yellow and green all are printing nicely. Yellow looks almost transparent, red looks awesome as always, and green is pretty close to grass green filament. The green seemed a little bit more touchy to cure times/settings, so red/yellow are seeming to be the most 'universal' as far as ease of use
SeeMeCNC Co-Founder & V.P.
Re: Makerjuice G+
Postby mhackney » Thu Aug 07, 2014 9:11 am
Do you cure the part in the Droplit using the projector or with an external curing "oven"?
sgraber
Re: Makerjuice G+
Postby sgraber » Thu Aug 07, 2014 9:20 am
The part will come out cured. You need to wash it off with isopropanol and let it dry. You can either further cure it by buying a cheap UV fingernail oven off Ebay or you can set it out in the sun. :)
artexmg
Re: Makerjuice G+
Postby artexmg » Mon Sep 08, 2014 11:05 pm
sgraber wrote:The part will come out cured. You need to wash it off with isopropanol and let it dry. You can either further cure it by buying a cheap UV fingernail oven off Ebay or you can set it out in the sun. :)
I understand that, if left under sun (wavelenght > 400nm), the resin will turn yellowish. I had said that, for preserving all clarity, the UV wavelength should be <300 nm.t
I had another (*caugh*) SLA printer and, at least with clear resin, it gets all yellowish if post-cured at sunlight. What I do not know is if this true for all resins, or not. I am just starting to get the grasp of SLA ;-)
If not, then a good UV oven is in need. I would go for LED UV (I'd seen 263nm UV leds) instead a bulb.
Lots of fun! (even though I am NOT a Beta Tester!! (yes, I missed the boat ... yes, I am anxious for the new boat) :-)
artexmg
Re: Makerjuice G+
Postby artexmg » Mon Sep 08, 2014 11:15 pm
Hey! I just realized that you KNOW about resins! :-)
So, for dropLit, is it not need to post-cure it? why not?
Also, is it the same to use a UV bulb than a LED? or one is better than other (I prefer LED than Bulbs, but only for the "easiness" of use)
Thanks for your answers!
sgraber
Re: Makerjuice G+
Postby sgraber » Tue Sep 09, 2014 9:25 am
Post curing certainly won't hurt it, and you can either buy a dedicated UV fingernail curing box (LED or CF; doesn't matter really) or just stick the parts out in the sun as both will do the same thing. Washing the parts really well in fresh isopropanol really will take care of the bulk of the uncured resin.
Return to “Resin Materials”
Who is online
