BeBoPr++
bubbasnow
ULTIMATE 3D JEDDI
BeBoPr++
Postby bubbasnow » Thu Jun 26, 2014 7:23 pm
I picked 2 of these up a while back finally getting time to document the work ive been doing getting this to work with a delta.
Ive populated it with 4 http://www.panucatt.com/product_p/sd8825.htm
Ill be powering it with http://www.ebay.com/itm/271159932338?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649
Im controlling it with https://www.adafruit.com/product/1876
ive flashed the eMMC with the 7.4 machinekit image from here http://www.machinekit.net/deb/rootfs/wheezy/
teoman
ULTIMATE 3D JEDDI
Re: BeBoPr++
Postby teoman » Fri Nov 21, 2014 6:47 am
Did you manage to get it working with LinuxCNC?
The more i fiddle with the printer, the more upgrades i want to do. And linux seems like a good route.
bubbasnow
ULTIMATE 3D JEDDI
Re: BeBoPr++
Postby bubbasnow » Fri Nov 21, 2014 6:08 pm
626Pilot
ULTIMATE 3D JEDDI
Re: BeBoPr++
Postby 626Pilot » Sun Sep 27, 2015 8:19 am
I'm trying to get some more information put together while I evaluate the BeagleBone solution. Can you post:
- What OS you're using, how you downloaded it, and how you flashed it
- How you installed MachineKit
- What display you're using, where you got it, and what you had to do to set it up
- Where you got your hardware
- Anything else that might have changed since you started the thread
bubbasnow
ULTIMATE 3D JEDDI
Re: BeBoPr++
Postby bubbasnow » Sat Oct 03, 2015 10:37 pm
626Pilot wrote:I'm trying to get some more information put together while I evaluate the BeagleBone solution. Can you post:
Sorry was away for the week,
-OS is debian, standard for revC versions of BBB
-Machinekit was pre-installed ver 2.7 pre
-I have a monitor directly hooked up, i an running TKEMC interface because large gcode files crash axis interface, hdmi port is supported out of the box.
-I purchased bebopr++ and pepper and step-5 directly from the creator Bas.
-stuff ive changed... ive had to update addresses of file locations because of the newer methods of configurations that machinekit uses.
Return to “Beaglebone Black”
Who is online
