BeBoPr++
bubbasnow
BeBoPr++
Postby bubbasnow » Thu Jun 26, 2014 7:23 pm
I picked 2 of these up a while back finally getting time to document the work ive been doing getting this to work with a delta.
Ive populated it with 4 http://www.panucatt.com/product_p/sd8825.htm
Ill be powering it with http://www.ebay.com/itm/271159932338?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649
Im controlling it with https://www.adafruit.com/product/1876
ive flashed the eMMC with the 7.4 machinekit image from here http://www.machinekit.net/deb/rootfs/wheezy/
teoman
Re: BeBoPr++
Postby teoman » Fri Nov 21, 2014 6:47 am
Did you manage to get it working with LinuxCNC?
The more i fiddle with the printer, the more upgrades i want to do. And linux seems like a good route.
bubbasnow
Re: BeBoPr++
Postby bubbasnow » Fri Nov 21, 2014 6:08 pm
626Pilot
Re: BeBoPr++
Postby 626Pilot » Sun Sep 27, 2015 8:19 am
I'm trying to get some more information put together while I evaluate the BeagleBone solution. Can you post:
- What OS you're using, how you downloaded it, and how you flashed it
- How you installed MachineKit
- What display you're using, where you got it, and what you had to do to set it up
- Where you got your hardware
- Anything else that might have changed since you started the thread
bubbasnow
Re: BeBoPr++
Postby bubbasnow » Sat Oct 03, 2015 10:37 pm
626Pilot wrote:I'm trying to get some more information put together while I evaluate the BeagleBone solution. Can you post:
Sorry was away for the week,
-OS is debian, standard for revC versions of BBB
-Machinekit was pre-installed ver 2.7 pre
-I have a monitor directly hooked up, i an running TKEMC interface because large gcode files crash axis interface, hdmi port is supported out of the box.
-I purchased bebopr++ and pepper and step-5 directly from the creator Bas.
-stuff ive changed... ive had to update addresses of file locations because of the newer methods of configurations that machinekit uses.
Return to “Beaglebone Black”
Who is online
Users browsing this forum: No registered users and 2 guests
