accelerometer probe on smoothieboard?
KAS
ULTIMATE 3D JEDDI
Post by KAS » Mon Sep 19, 2016 12:51 pm
Is it possible to use the SeeMeCNC accelerator probe on smoothieboard?
ULTIMATE 3D JEDDI
Re: accelerometer probe on smoothieboard?
Post by Jimustanguitar » Tue Sep 20, 2016 8:08 am
Also curious about this on Duet. Anybody know?
ULTIMATE 3D JEDDI
Post by mhackney » Tue Sep 20, 2016 8:54 am
I don't have the accelerometer board yet but it should just work from what I've seen and read. Looking at the Configuration.h it simply interfaces to a single pin and looks like an endstop port and gives a simple binary on/off signal like a simple mechanical switch.
ULTIMATE 3D JEDDI
Post by geneb » Tue Sep 20, 2016 9:52 am
My understanding is that it uses an I2C interface...
ULTIMATE 3D JEDDI
Post by mhackney » Tue Sep 20, 2016 10:39 am
I would think that would require some significant changes to repetier firmware to support? I looked at the repetier sources quickly and did not see anything out of the ordinary. This is where the pin is defined in Configuration.h:
/* #################### Z-Probe configuration and Settings #####################
   These will change machine to machine, be sure to have the correct machine selected in the top of this config file
// 301 = RAMBO    302 = MINI_RAMBO
#if MOTHERBOARD == 301
#define Z_PROBE_PIN 4
#elif MOTHERBOARD == 302
#define Z_PROBE_PIN 16
#endif
I've never quit figured out how repetier firmware maps to pins defined at http://reprap.org/wiki/Rambo_development (and it has been several years since I've used a RAMBo).
Hey - you have a V3! Where does it plug into RAMBo and how many pins does it use?
ULTIMATE 3D JEDDI
Post by mhackney » Tue Sep 20, 2016 11:42 am
Yup, I2C http://seemecnc.dozuki.com/Guide/Step+4 ... ssembly/44
I looked at the sources again and still did not find anything special to support the probe.
ULTIMATE 3D JEDDI
Post by geneb » Tue Sep 20, 2016 11:44 am
I took all those pics...so yeah. :)
ULTIMATE 3D JEDDI
Post by mhackney » Tue Sep 20, 2016 11:45 am
Show off. :roll:
What do you know about the code to support the probe?
KAS
ULTIMATE 3D JEDDI
Post by KAS » Tue Sep 20, 2016 12:41 pm
Okay, well at least it's possible since smoothie has an I2C header. Hopefully the coding is something simple.
ULTIMATE 3D JEDDI
Post by geneb » Tue Sep 20, 2016 12:45 pm
I don't know anything about it. I think the next most knowledgeable guy is Kraegar....or bug Guanu. :)
Return to “Smoothieboard and variants”
