Weight versus length
Discuss filament successes and failures!
gajtguy
Post by gajtguy » Sat Dec 03, 2016 7:32 pm
Hi guys. Been a while since I posted my normal basic topics.. Here's another one. Whats the length of material on the SeeMeCNC .5kg spool (1.75 ABS)?? When I load a model in Cura it tells me how much length is required, and I'm not sure how much the .5KG holds.
On another note, if a print is happening and the spool is about to run out, what is your process to join another spool into the mix? Or is that not possible?
Thanks
Qdeathstar
Re: Weight versus length
Post by Qdeathstar » Sat Dec 03, 2016 7:55 pm
I have paused the print, pulled out the old filament and put the longer piece in and resumed printing, The results after a moderate amount of sanding were good. My only issue was that i was shining LEDS through it, and you could tell the difference in quality between matterhackers and hatchbox filament (matterhackers was much whiter - better).
As far as length per kg, that depends on the density of the material, and it varies even between different colors of ABS.
Approximations:
PLA
Density: 1.25 g/cm^3
Volume: 0.80 cm^3/g or 800 cm^3/kg
1.75 mm filament length for 1 kg spool: ~ 330 meters / ~ 1080 feet
3.00 mm filament length for 1 kg spool: ~ 110 meters / ~ 360 feet
ABS
Density: 1.04 g/cm^3
Volume: 0.96 cm^3/g or 960 cm^3/kg
1.75 mm filament length for 1 kg spool: ~ 400 meters / ~ 1310 feet
3.00 mm filament length for 1 kg spool: ~ 130 meters / ~ 430 feet
https://www.toybuilderlabs.com/blogs/ne ... and-length
nebbian
Post by nebbian » Sun Dec 04, 2016 10:46 pm
I've used this calculator a bit to give me a reasonable idea of how to convert length to weight:
http://3deee.ch/3deeeMaterialCalculator4.php
Return to “Filament”
