Multiple Object Print - Only one slices?
aodhan
Postby aodhan » Sat Jan 07, 2017 3:31 pm
I've used the "insert" function to make a 15-up arrangement of some small parts. When I slice, only one slices. The kicker is that the one isn't even the original added object... Any ideas what the heck is going on?
Thanks,
-Matt
Layer VIew
3D View
Jefrysuko
Re: Multiple Object Print - Only one slices?
Postby Jefrysuko » Wed Jan 11, 2017 1:21 pm
You need to save your 3D View window before going to Layer View.
aodhan
Postby aodhan » Sat Feb 25, 2017 12:18 pm
Jefrysuko wrote:You need to save your 3D View window before going to Layer View.
Thanks for the reply. I was doing this. I also went so far as to make an stl with multiple shells. It worked with other files but still wasn't working for this one. It wasn't until I decided to change my pre-defined print settings for that file to another one just to see what would happen. It worked! But why?
I dug into the settings and realized Spiral Vase was set to 1. :oops:
In case you're running into the same issue I did - make sure Spiral Vase is NOT enabled. Mattercontrol will not let you slice multiple shells when you have Spiral Vase enabled!
-Matt
Return to “MatterControl”
Who is online
