Changing Spools mid print using SD card
elwooddbeauchamp
Post by elwooddbeauchamp » Tue Jul 22, 2014 11:44 pm
I am printing from SD card, and being new at this venture, could someone share their procedure for changing to a new spool, same material, mid print on the Rostock Max v2 using the SD card...Thanks
Momma told me "You need to work on your Printing"
SoCalSteve
Re: Changing Spools mid print using SD card
Post by SoCalSteve » Wed Oct 01, 2014 4:20 pm
I'm interested in this as well. did you ever find out anything?
Nylocke
ULTIMATE 3D JEDDI
Post by Nylocke » Wed Oct 01, 2014 4:31 pm
In the LCD menu under the SD card menu there is a "pause print" option. Pause it, swap it, resume it. Should work fine (just try to pause it on the infil as to not screw up the perimeters).
If you have a specific spot you want to pause it and switch it at you can add some fancy G-code to lift and pause on that line.
SoCalSteve
Post by SoCalSteve » Wed Oct 01, 2014 4:46 pm
Nylocke wrote:In the LCD menu under the SD card menu there is a "pause print" option. Pause it, swap it, resume it. Should work fine (just try to pause it on the infil as to not screw up the perimeters).
Awesome, Thanks!
elwooddbeauchamp
Post by elwooddbeauchamp » Fri Oct 03, 2014 12:35 pm
Thanks, Mylocke
Return to “Rostock MAX v2”
