Deform shape
richardphat
Deform shape
Post by richardphat » Mon Jun 16, 2014 8:09 pm
Hello, I have this problem when I start printing ABS.
Say I have a circle shape on a CAD files, I end up getting some elliptic shape. Or if I want to print a prism, the lines aren't that straight. The bed level calibration were done carefully though and I had to adjust the horizontal radius, so I believe level calibration isnt the issue.
Could this be related to inappropriate belt tension or too much resistance on the axis?
Holy1
Re: Deform shape
Post by Holy1 » Mon Jun 16, 2014 9:12 pm
Check for seized or tight u-joints.
Orion to Cartesian viewtopic.php?f=59&t=7808
McSlappy
Re: Deform shape
Post by McSlappy » Mon Jun 16, 2014 9:55 pm
^ this. I'd almost guarantee it's a stiff u joint.
richardphat
Re: Deform shape
Post by richardphat » Mon Jun 16, 2014 11:08 pm
Hi again,
are you refering the u joints from the effector or the ones that are screwed to the cheapskate carriage?
nitewatchman
Re: Deform shape
Post by nitewatchman » Tue Jun 17, 2014 12:32 am
Could be either one and at either the arm to aluminum block or the block to the shaft.
nitewatchman
richardphat
Re: Deform shape
Post by richardphat » Thu Jun 19, 2014 4:30 pm
Hi, I confirm that the u joints get moved easily. The screw that hold the carriage are tight though, what did you guys do in order to fix it?
richardphat
Re: Deform shape
Post by richardphat » Mon Jun 30, 2014 4:55 pm
Hi, I just wanted to give an update. I somehow managed to solve the problem. The carriage has too much friction on the T extruded, and as a result there was 2 carriage that could move freely out of 3.
So I adjusted the screw and now the 3 carriages could move freely without much friction.
It is now printed a circle fine.
Return to “Rostock MAX v2”
