Error compiling
Posted: Fri Sep 14, 2018 1:07 pm
by bauf
So i just cleared my eeprom on my max 2 and now when i try to upload firmware 0.91, i get this message: error compiling for board arduino/genuino mega or mega 2560
I'm a noob when it comes to this, so i have no clue what's wrong here. :o
Arduino: 1.8.7 (Windows 10), Board: "Arduino/Genuino Mega or Mega 2560, ATmega2560 (Mega 2560)"
In file included from sketch\ui.h:189:0,
                 from sketch\Repetier.h:256,
                 from sketch\SDCard.cpp:22:
sketch\uilang.h:1202:0: warning: "UI_TEXT_PRINT_POS" redefined
 #define UI_TEXT_PRINT_POS        "Percent Printed:"
sketch\uilang.h:92:0: note: this is the location of the previous definition
 #define UI_TEXT_PRINT_POS        "Printing..."
sketch\uilang.h:1204:0: warning: "UI_TEXT_IDLE" redefined
 #define UI_TEXT_IDLE             "ROSTOCKMAX OK"
sketch\uilang.h:94:0: note: this is the location of the previous definition
 #define UI_TEXT_IDLE             "Idle"
sketch\uilang.h:1207:0: warning: "UI_TEXT_BACK" redefined
 #define UI_TEXT_BACK             "Previous Screen \001"
sketch\uilang.h:97:0: note: this is the location of the previous definition
 #define UI_TEXT_BACK             "Back \001"
sketch\uilang.h:1208:0: warning: "UI_TEXT_QUICK_SETTINGS" redefined
 #define UI_TEXT_QUICK_SETTINGS   "Printer Settings"
sketch\uilang.h:98:0: note: this is the location of the previous definition
 #define UI_TEXT_QUICK_SETTINGS   "Quick Settings"
sketch\uilang.h:1209:0: warning: "UI_TEXT_CONFIGURATION" redefined
 #define UI_TEXT_CONFIGURATION    "Advanced Settings"
sketch\uilang.h:99:0: note: this is the location of the previous definition
 #define UI_TEXT_CONFIGURATION    "Configuration"
sketch\uilang.h:1213:0: warning: "UI_TEXT_SD_CARD" redefined
 #define UI_TEXT_SD_CARD          "SD Card Menu"
sketch\uilang.h:102:0: note: this is the location of the previous definition
 #define UI_TEXT_SD_CARD          "SD Card"
sketch\uilang.h:1215:0: warning: "UI_TEXT_HOME_ALL" redefined
 #define UI_TEXT_HOME_ALL         "Home Towers"
sketch\uilang.h:105:0: note: this is the location of the previous definition
 #define UI_TEXT_HOME_ALL         "Home All"
sketch\uilang.h:1229:0: warning: "UI_TEXT_Z_POS_FAST" redefined
 #define UI_TEXT_Z_POS_FAST       "Move Z Position"
sketch\uilang.h:120:0: note: this is the location of the previous definition
 #define UI_TEXT_Z_POS_FAST       "Z Pos. Fast"
sketch\uilang.h:1240:0: warning: "UI_TEXT_EXTR2_SELECT" redefined
 #define UI_TEXT_EXTR2_SELECT     "%X1 Select Extr.2"
                 from sketch\Eeprom.cpp:24:
sketch\uilang.h:131:0: note: this is the location of the previous definition
 #define UI_TEXT_EXTR2_SELECT     "%X2 Select Extr.2"
sketch\uilang.h:1246:0: warning: "UI_TEXT_MOVE_X" redefined
 #define UI_TEXT_MOVE_X           "Move X:%aX"
sketch\uilang.h:137:0: note: this is the location of the previous definition
 #define UI_TEXT_MOVE_X           "Move X :%aX"
sketch\uilang.h:1247:0: warning: "UI_TEXT_MOVE_Y" redefined
 #define UI_TEXT_MOVE_Y           "Move Y:%aY"
sketch\uilang.h:138:0: note: this is the location of the previous definition
 #define UI_TEXT_MOVE_Y           "Move Y :%aY"
sketch\uilang.h:1248:0: warning: "UI_TEXT_MOVE_Z" redefined
 #define UI_TEXT_MOVE_Z           "Move Z:%aZ"
sketch\uilang.h:139:0: note: this is the location of the previous definition
 #define UI_TEXT_MOVE_Z           "Move Z :%aZ"
sketch\uilang.h:1250:0: warning: "UI_TEXT_JERK" redefined
 #define UI_TEXT_JERK             "Jerk:%aj"
sketch\uilang.h:141:0: note: this is the location of the previous definition
 #define UI_TEXT_JERK             "Jerk   :%aj"
sketch\uilang.h:1251:0: warning: "UI_TEXT_ZJERK" redefined
 #define UI_TEXT_ZJERK            "Z-Jerk:%aJ"
sketch\uilang.h:142:0: note: this is the location of the previous definition
 #define UI_TEXT_ZJERK            "Z-Jerk :%aJ"
                 from sketch\Communication.cpp:22:
                 from sketch\Commands.cpp:22:
                 from sketch\gcode.cpp:24:
                 from sketch\motion.cpp:24:
                 from C:\Users\Bauf\Downloads\Repetier-091-ROSTOCKMAX-master (1)\Repetier-091-ROSTOCKMAX-master\Repetier-091-ROSTOCKMAX\Repetier\Repetier.ino:134:
                 from sketch\ui.cpp:20:
                 from sketch\Printer.cpp:19:
                 from sketch\SdFat.cpp:20:
sketch\uilang.h:1254:0: warning: "UI_TEXT_LOAD_EEPROM" redefined
 #define UI_TEXT_LOAD_EEPROM      "Load from EEPROM"
sketch\uilang.h:145:0: note: this is the location of the previous definition
 #define UI_TEXT_LOAD_EEPROM      "Load f. EEPROM"
                 from sketch\HAL.cpp:1:
                 from sketch\Extruder.cpp:22:
sketch\uilang.h:1262:0: warning: "UI_TEXT_OPS_RETRACT" redefined
 #define UI_TEXT_OPS_RETRACT      "Retract :%Or"
sketch\uilang.h:153:0: note: this is the location of the previous definition
sketch\uilang.h:1263:0: warning: "UI_TEXT_OPS_BACKSLASH" redefined
 #define UI_TEXT_OPS_BACKSLASH    "Backsl. :%Ob"
sketch\uilang.h:154:0: note: this is the location of the previous definition
sketch\uilang.h:1264:0: warning: "UI_TEXT_OPS_MINDIST" redefined
 #define UI_TEXT_OPS_MINDIST      "Min.dist:%Od"
sketch\uilang.h:155:0: note: this is the location of the previous definition
 #define UI_TEXT_OPS_MINDIST      "Min.dist  :%Od"
sketch\uilang.h:1267:0: warning: "UI_TEXT_PRINT_FILE" redefined
 #define UI_TEXT_PRINT_FILE       "Select File"
sketch\uilang.h:158:0: note: this is the location of the previous definition
 #define UI_TEXT_PRINT_FILE       "Print file"
sketch\uilang.h:1295:0: warning: "UI_TEXT_FANSPEED" redefined
 #define UI_TEXT_FANSPEED          "Adjust Fan Speed"
sketch\uilang.h:186:0: note: this is the location of the previous definition
 #define UI_TEXT_FANSPEED          "Fan speed"
sketch\uilang.h:1301:0: warning: "UI_TEXT_FAN_FULL" redefined
 #define UI_TEXT_FAN_FULL          "Set Fan to 100%%%"
sketch\uilang.h:192:0: note: this is the location of the previous definition
 #define UI_TEXT_FAN_FULL          "Set Fan Full"
sketch\uilang.h:1340:0: warning: "UI_TEXT_FLOW_MULTIPLY" redefined
 #define UI_TEXT_FLOW_MULTIPLY     "Flow Mul.:%of%%%"
sketch\uilang.h:231:0: note: this is the location of the previous definition
 #define UI_TEXT_FLOW_MULTIPLY     "Flow Mul. :%of%%%"
sketch\uilang.h:1341:0: warning: "UI_TEXT_EXTR_WAIT_RETRACT_TEMP" redefined
 #define UI_TEXT_EXTR_WAIT_RETRACT_TEMP  "Wait Temp.%XT\002C"
sketch\uilang.h:241:0: note: this is the location of the previous definition
 #define UI_TEXT_EXTR_WAIT_RETRACT_TEMP "Wait Temp. %XT\002C"
sketch\uilang.h:1342:0: warning: "UI_TEXT_EXTR_WAIT_RETRACT_UNITS" redefined
 #define UI_TEXT_EXTR_WAIT_RETRACT_UNITS "Wait Units:%XUmm"
sketch\uilang.h:242:0: note: this is the location of the previous definition
 #define UI_TEXT_EXTR_WAIT_RETRACT_UNITS "Wait Units: %XU mm"
sketch\uilang.h:1343:0: warning: "UI_TEXT_PRINTER_READY" redefined
 #define UI_TEXT_PRINTER_READY    "ROSTOCK MAX OK"
sketch\uilang.h:245:0: note: this is the location of the previous definition
 #define UI_TEXT_PRINTER_READY    "Printer ready."
sketch\uilang.h:1349:0: warning: "UI_TEXT_PRINT_TIME" redefined
 #define UI_TEXT_PRINT_TIME     "Total Time Printing"
sketch\uilang.h:251:0: note: this is the location of the previous definition
 #define UI_TEXT_PRINT_TIME     "Printing time"
sketch\uilang.h:1350:0: warning: "UI_TEXT_PRINT_FILAMENT" redefined
 #define UI_TEXT_PRINT_FILAMENT "Total Filament Used"
sketch\uilang.h:252:0: note: this is the location of the previous definition
 #define UI_TEXT_PRINT_FILAMENT "Filament printed"
In file included from sketch\ui.h:1024:0,
sketch\uilang.h:92:0: warning: "UI_TEXT_PRINT_POS" redefined
sketch\uilang.h:1202:0: note: this is the location of the previous definition
sketch\uilang.h:94:0: warning: "UI_TEXT_IDLE" redefined
sketch\uilang.h:1204:0: note: this is the location of the previous definition
sketch\uilang.h:97:0: warning: "UI_TEXT_BACK" redefined
sketch\uilang.h:1207:0: note: this is the location of the previous definition
sketch\uilang.h:98:0: warning: "UI_TEXT_QUICK_SETTINGS" redefined
sketch\uilang.h:1208:0: note: this is the location of the previous definition
sketch\uilang.h:99:0: warning: "UI_TEXT_CONFIGURATION" redefined
sketch\uilang.h:1209:0: note: this is the location of the previous definition
sketch\uilang.h:102:0: warning: "UI_TEXT_SD_CARD" redefined
sketch\uilang.h:1213:0: note: this is the location of the previous definition
sketch\uilang.h:105:0: warning: "UI_TEXT_HOME_ALL" redefined
sketch\uilang.h:1215:0: note: this is the location of the previous definition
sketch\uilang.h:120:0: warning: "UI_TEXT_Z_POS_FAST" redefined
sketch\uilang.h:1229:0: note: this is the location of the previous definition
sketch\uilang.h:131:0: warning: "UI_TEXT_EXTR2_SELECT" redefined
sketch\uilang.h:1240:0: note: this is the location of the previous definition
sketch\uilang.h:137:0: warning: "UI_TEXT_MOVE_X" redefined
sketch\uilang.h:1246:0: note: this is the location of the previous definition
sketch\uilang.h:138:0: warning: "UI_TEXT_MOVE_Y" redefined
sketch\uilang.h:1247:0: note: this is the location of the previous definition
sketch\uilang.h:139:0: warning: "UI_TEXT_MOVE_Z" redefined
sketch\uilang.h:1248:0: note: this is the location of the previous definition
sketch\uilang.h:141:0: warning: "UI_TEXT_JERK" redefined
sketch\uilang.h:1250:0: note: this is the location of the previous definition
sketch\uilang.h:142:0: warning: "UI_TEXT_ZJERK" redefined
sketch\uilang.h:1251:0: note: this is the location of the previous definition
sketch\uilang.h:145:0: warning: "UI_TEXT_LOAD_EEPROM" redefined
sketch\uilang.h:1254:0: note: this is the location of the previous definition
sketch\uilang.h:153:0: warning: "UI_TEXT_OPS_RETRACT" redefined
sketch\uilang.h:1262:0: note: this is the location of the previous definition
sketch\uilang.h:154:0: warning: "UI_TEXT_OPS_BACKSLASH" redefined
sketch\uilang.h:1263:0: note: this is the location of the previous definition
sketch\uilang.h:155:0: warning: "UI_TEXT_OPS_MINDIST" redefined
sketch\uilang.h:1264:0: note: this is the location of the previous definition
sketch\uilang.h:158:0: warning: "UI_TEXT_PRINT_FILE" redefined
sketch\uilang.h:1267:0: note: this is the location of the previous definition
sketch\uilang.h:186:0: warning: "UI_TEXT_FANSPEED" redefined
sketch\uilang.h:1295:0: note: this is the location of the previous definition
sketch\uilang.h:192:0: warning: "UI_TEXT_FAN_FULL" redefined
sketch\uilang.h:1301:0: note: this is the location of the previous definition
sketch\uilang.h:231:0: warning: "UI_TEXT_FLOW_MULTIPLY" redefined
sketch\uilang.h:1340:0: note: this is the location of the previous definition
sketch\uilang.h:241:0: warning: "UI_TEXT_EXTR_WAIT_RETRACT_TEMP" redefined
sketch\uilang.h:1341:0: note: this is the location of the previous definition
sketch\uilang.h:242:0: warning: "UI_TEXT_EXTR_WAIT_RETRACT_UNITS" redefined
sketch\uilang.h:1342:0: note: this is the location of the previous definition
sketch\uilang.h:245:0: warning: "UI_TEXT_PRINTER_READY" redefined
sketch\uilang.h:1343:0: note: this is the location of the previous definition
sketch\uilang.h:251:0: warning: "UI_TEXT_PRINT_TIME" redefined
sketch\uilang.h:1349:0: note: this is the location of the previous definition
sketch\uilang.h:252:0: warning: "UI_TEXT_PRINT_FILAMENT" redefined
sketch\uilang.h:1350:0: note: this is the location of the previous definition
In file included from sketch\Repetier.h:369:0,
sketch\motion.h:653:26: warning: extra tokens at end of #ifdef directive
 #ifdef SOFTWARE_LEVELING && DRIVE_SYSTEM==3
sketch\motion.cpp:345:32: warning: extra tokens at end of #ifdef directive
 #ifdef ENABLE_QUADRATIC_ADVANCE;
In file included from sketch\Repetier.h:256:0,
sketch\Commands.cpp: In static member function 'static void Commands::emergencyStop()':
sketch\ui.h:1056:56: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
 #define UI_STATUS_UPD_RAM(status) {uid.setStatus(status);uid.refreshPage();}
sketch\Commands.cpp:1436:3: note: in expansion of macro 'UI_STATUS_UPD_RAM'
   UI_STATUS_UPD_RAM("RESETTING/E-STOP");
sketch\motion.cpp:1143:26: warning: extra tokens at end of #ifdef directive
sketch\SDCard.cpp: In member function 'void SDCard::initsd()':
sketch\SDCard.cpp:98:32: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
     if(selectFile("init.g",true))
In file included from sketch\ui.h:1025:0,
sketch\uimenu.h:303:19: warning: extra tokens at end of #ifdef directive
 #ifdef Z_HOME_DIR < 0
sketch\uimenu.h:508:0: warning: "UI_MENU_ADV_CNT" redefined
 #define UI_MENU_ADV_CNT 1
sketch\uimenu.h:505:0: note: this is the location of the previous definition
 #define UI_MENU_ADV_CNT 0
sketch\uimenu.h:509:0: warning: "UI_MENU_ADVANCE" redefined
 #define UI_MENU_ADVANCE ,&ui_menu_cext_advancel
sketch\uimenu.h:506:0: note: this is the location of the previous definition
sketch\uimenu.h:567:18: warning: extra tokens at end of #ifdef directive
 #ifdef Z_HOME_DIR<0
sketch\motion.cpp: In static member function 'static void PrintLine::updateTrapezoids()':
sketch\motion.cpp:432:27: warning: integer overflow in expression [-Woverflow]
     while(timeleft < 4500 * MOVE_CACHE_SIZE && maxfirst != linesWritePos)
sketch\ui.cpp:831:75: warning: '__progmem__' attribute ignored [-Wattributes]
 void UIDisplay::createChar(uint8_t location,const uint8_t PROGMEM charmap[])
sketch\SdFat.cpp: In member function 'uint8_t Sd2Card::cardCommand(uint8_t, uint32_t)':
sketch\SdFat.cpp:3202:23: warning: narrowing conversion of '(int)(cmd | 64u)' from 'int' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
   uint8_t d[6] = {cmd | 0X40, pa[3], pa[2], pa[1], pa[0]};
C:\Users\Bauf\AppData\Local\Temp\ccnK5zcJ.ltrans2.ltrans.o: In function `__vector_17':
<artificial>:(.text+0x214): undefined reference to `stepperWait'
<artificial>:(.text+0x21c): undefined reference to `stepperWait'
<artificial>:(.text+0x224): undefined reference to `stepperWait'
<artificial>:(.text+0x232): undefined reference to `stepperWait'
<artificial>:(.text+0x236): undefined reference to `stepperWait'
C:\Users\Bauf\AppData\Local\Temp\ccnK5zcJ.ltrans2.ltrans.o:<artificial>:(.text+0x23c): more undefined references to `stepperWait' follow
collect2.exe: error: ld returned 1 exit status
exit status 1
Error compiling for board Arduino/Genuino Mega or Mega 2560.
This report would have more information with
"Show verbose output during compilation"
option enabled in File -> Preferences.
Re: Error compiling
Posted: Fri Sep 14, 2018 4:52 pm
by Xenocrates
You are using too new of a version of the Arduino IDE. try version 1.6.0
