HE280 Upgrade and Extruder Stepper Stops Workig
RussD
Postby RussD » Mon Dec 04, 2017 10:00 pm
Hi All,
I just upgraded my HE280 hoted and got it calibrating fine.
Also upgraded to Repetier 92.2 and I think I have the configuration.h setup correctly for my setup. But when I connect to MatterControl and try to get the extruder motor to run, it does nothing. The stepper is not engaged at all. I have done some searching on the forum here where folks have gone into the pins.h and swapped the pins associated with E0 and E1. I did that and had no luck with the stepper plug in either the E0 or E1 slot.
Interestingly I did some basic troubleshooting with the XY and Z steppers by putting the extruder plug in the X position. The extruder responded fine. So I think the wiring and stepper are ok for the extruder. I also put the X stepper in the E0 and E1 connections and no joy. So either I have a firmware configuration issue still or blew out the E0 and E1 plugs on the Rambo.
Any suggestions out there?
Thanks for any help you can provide.
Russ
pouncingiguana
Re: HE280 Upgrade and Extruder Stepper Stops Workig
Postby pouncingiguana » Tue Dec 05, 2017 7:28 am
Make sure the you've got a high enough temperature on the hot end to extrude. 92.2 won't run the extruders if the hot end is less than 150 degrees.
RussD
Postby RussD » Thu Dec 07, 2017 5:59 pm
pouncingiguana wrote:Make sure the you've got a high enough temperature on the hot end to extrude. 92.2 won't run the extruders if the hot end is less than 150 degrees.
Oh yeah. I feel dumb. You are correct though. Once I had things heated up it started working. At least I learned a lot about configuring the firmware in the process.
So I ended up replacing the trucks and got the new ball arms at the same time as upgrading the HE280. I had stepped away from the machine after getting frustrated with leveling over a year ago. But now it is running better than it ever had before and I am loving the Rostock again.
I can say that everything including software, firmware, and hardware has made some improvements over the last year.
Thanks for the reminders.
Russ
Who is online
