arduino "avrdude: stk500v2_ReceiveMessage(): timeout"
aid4nsmith
Post by aid4nsmith » Fri Jul 28, 2017 9:36 am
Whilst going through the users manual, I make it to the eeprom clear example which when i try to upload gives the message:
avrdude: stk500v2_getsync(): timeout communicating with programmer
The RX LED flashes orange however the TX LED does not flash at all.
I'm using Arduino 1.8.3
I have the correct board as stated in the User's manual:
Board: Arduino Mega 2560
Any help please?
lightninjay
Re: arduino "avrdude: stk500v2_ReceiveMessage(): timeout"
Post by lightninjay » Fri Jul 28, 2017 10:51 am
The fourth to last line of your post is most likely your issue.
Try Arduino 1.6
aid4nsmith
Post by aid4nsmith » Fri Jul 28, 2017 12:07 pm
lightninjay wrote:The fourth to last line of your post is most likely your issue.
Try Arduino 1.6
downloaded 1.6.0 and still same message :/
lightninjay
Post by lightninjay » Mon Jul 31, 2017 8:26 am
A search of google for the error message brought me to a Stackoverflow page regarding MEGA 2560 boards. There are several points mentioned which could possibly be the cause for this message. The following link lists them:
https://stackoverflow.com/revisions/767 ... iew-source
One potential issue is that you do not have the proper drivers for the RAMBo installed on your PC. Another more serious issue would be that your RAMBo has a corrupt/nonexistent bootloader.
CarlJ
Post by CarlJ » Wed Oct 04, 2017 4:16 pm
Hello, this might not be relevant, I had the same problem today.
Was connected to Rostock max v2 thru matter control at the same time I was trying to compile and upload to Arduino.
Found that I had to disconnect the printer from Matter Control program, than was able to upload new compile.
Felt really embarrassed, but nobody around. :oops:
CarlJ
Return to “Rostock MAX v2”
