E3d install Questions/Help
Hello all!
I have a few questions regarding the new e3d v6 thermistor and bowden setup.
First up the new cartridge thermistor e3d includes does this require different values than what listed on the matthackers guide?
Second how do you remove the bowden tube when you want to switch rolls
third what would be good retract settings to use.
Thanks is advance Im excited to get this rolling the e3d v6 was a vast improvement on my prusa hopping for similar results.
- Xenocrates
- ULTIMATE 3D JEDDI
Re: E3d install Questions/Help
So, it should be a sensor type 8 for the cartridge, this lines up between E3D's doc's, repetier's docs for the sensor, and matterhackers. Secondly, if you want to remove the bowden tube, you can push down on the connector on either the hotend or the extruder, however in almost no case do you need to remove the bowden tube to change plastic, as you can press the red release button, and pull on the filament once you're at temperature. Thirdly, 1-2 mm of retract at 10-20mm/s is a usual starting point. Different filaments will want different settings. If you're using something on your Prusa retraction wise, it should work fine for the Max, when they both have the same hotend.
Thank you for the info Im going to install it tonight.
might be a dumb question but can i edit the firmware via matter control for the thermistor? Or do i need to reupload through audrino?
- Xenocrates
- ULTIMATE 3D JEDDI
You'll have to re-upload the firmware via the Arduino IDE or similar.
Alright I uploaded new firmware now my led ring is flashing constantly.
Have everything set according to manual any Ideas?
- ULTIMATE 3D JEDDI
How is the LED Ring wired?
I wired it with the peek fan.
