Mach3 - 3Axis Board with easyDriver Configuration
All things related to Mach3 CNC software
PartDaddy
Post by PartDaddy » Mon May 14, 2012 11:24 am
Anyone updating the RepRap wiki page, is welcome to transfer any of this information. As of this posting date, we have begun shipping 4 axis control boards to make connection easier.
Using the 3 axis board with EasyDriver (4th axis), copy this file to the mach3 installation directory on your computer:
http://seemecnc.org/assembly/Slic3r%20Profile.xml
After putting this profile in the Mach3 installation folder, start Mach3 using the "Mach Loader". You will see "Slic3r Profile" in the list, click on it, Mach will start and all the settings will be correct.
This next file is a Slic3r configuration. I'm posting it here because all of this stuff works together. I am also going to post it in the other areas on our forum.
Slic3r_INI_SETUP_175mm_Filament_020_nozzle.ini
SeeMeCNC Mach3 INI File Slic3r 0.7.2b
(1.49 KiB) Downloaded 401 times
Oly & I keep these right in our STL folder where we keep our parts. Choose "load profile" after you start Slic3r. Usually, Slic3r is installed on a separate computer for g-code generation.
Here's a photo of the 3 axis board with easyDriver and wiring. This photo is also at http://seemecnc.org/assembly
SeeMeCNC H-1 3axis board with easyDriver wiring
ElectronRanchers photo of jumpered opto-isolators. Reference to Matt's Misc Photo album on the "SeeMeCNC YaHoo Group".
ElectronRanchers "SkewFixMod2" 3 Axis Board Jumpers
~PartDaddy
SeeMeCNC Owner & Founder
Since 1996
seemeadmin
Site Admin
Re: Mach3 - 3Axis Board with easyDriver Configuration
Post by seemeadmin » Wed May 23, 2012 7:49 pm
Some Slic3r Profiles to get you going!
viewtopic.php?f=13&t=641
wildideas1
Post by wildideas1 » Fri Jun 08, 2012 2:19 pm
ok my brain is fried and i need clarification on how do i get the files into mach3 when i click link it gives me long file and i tried to copy paste into but nothing will move over.
johnoly99
Post by johnoly99 » Sat Jun 09, 2012 9:03 am
Right click, and save link as. For the slic3r ini file, aave it into a folder in slic3r directiory, you will point to it when you click load config im slic3r
crob09
Post by crob09 » Mon Oct 07, 2013 12:05 am
Hi,
Just wondering if you could help with the mach-3 config .xml file, I can't seem to download it. I'm also in need of some help with the configuration file for the tb6560 without the easydriver attached, I have one of three motors turning, the Y-axis.
Any and all help greatly appreciated.
PartDaddy wrote:Anyone updating the RepRap wiki page, is welcome to transfer any of this information. As of this posting date, we have begun shipping 4 axis control boards to make connection easier.
Return to “Mach3 Software”
