GPIO
Talk about the web based OctoPrint controllers
bubbasnow
ULTIMATE 3D JEDDI
GPIO
Post by bubbasnow » Thu Feb 20, 2014 12:23 am
so now that i have the gpio figured out i went and purchased one of these..
then i grab a 3 gang with 2 pair(now totally controllable) outlets
then i persuade it to fit
solder the pinout onto a cat5 jack
then call it a night!!!!!
neurascenic
Re: GPIO
Post by neurascenic » Thu Feb 20, 2014 2:13 am
What do you plan on doing with the FPIOs?
Captain Starfish
Re: GPIO
Post by Captain Starfish » Thu Feb 20, 2014 3:00 am
Automatically fire up the kettle whilst you wait for the bed to heat up?
Eric
Re: GPIO
Post by Eric » Thu Feb 20, 2014 4:00 am
Don't forget to put a max amps label on it so nobody forgets there's only a 10A relay controlling that 15A outlet. That may rule out using it for the coffeemaker too.
bubbasnow
ULTIMATE 3D JEDDI
Re: GPIO
Post by bubbasnow » Thu Feb 20, 2014 5:15 pm
Im going N.O. on the config so someone would have to actually log into my RaspberryPI and switch it on for it to pass current.
bubbasnow
ULTIMATE 3D JEDDI
Re: GPIO
Post by bubbasnow » Thu Feb 20, 2014 5:16 pm
neurascenic wrote:What do you plan on doing with the FPIOs?
ill attach it to my printer cart and control lights, printer, bedpower.... i dont know what the last slot will be for but im sure i will fill it
bubbasnow
ULTIMATE 3D JEDDI
Re: GPIO
Post by bubbasnow » Fri Feb 21, 2014 10:31 pm
ok so here is the finished box, plugged in and tested with a desk lamp. i can now control all 4 plugs by just a click of the mouse via octopi
enggmaug
Re: GPIO
Post by enggmaug » Thu Sep 22, 2016 4:27 pm
I also used GPIOs on RPI2, and added corresponding controls in Octoprint, in order to turn on/off both the printer and the lights in my enclosure, directly from octoprint interface.
Difference is that in order to turn on/off the printer, my relay is connected to the very same wire as the on/off switch. (I have a V1, with a PC power supply, I don't know about other versions).
I found a way to put 2 connectors there, and depending which one connector I use to plug the relay, my relay comes either in parallel or serial with the switch.
This way I either need to have both relay and switch on to turn the printer on, or only one of them two.
Return to “OctoPrint”
