G-code for LCD Encoder?
Post your prints with the GCode used to help other users achieve a similar result, or get help.
jmargush
Postby jmargush » Fri Apr 01, 2016 1:35 am
I recently started this project to make my own custom pause G-code and I wanted to add a function to resume the print with the click of the encode on the LCD Panel. I looked on the Wiki page for possible commands that are compatible with the Repetier Firmware but I never found anything to use the encoder. Now I am wondering if it is possible to control the printer with the encoder to start the printer the way I want to. Suggestions or ideas would be greatly appreciated. Thanks for your time.
ULTIMATE 3D JEDDI
Re: G-code for LCD Encoder?
Postby Eaglezsoar » Fri Apr 01, 2016 4:22 am
Hi jmargush!
See this link, it may be of some help to you.
viewtopic.php?f=77&t=5916
Return to “GCode & Test Prints”
Who is online
