stl output not quite as i expected
http://freecadweb.org
teoman
ULTIMATE 3D JEDDI
Post by teoman » Fri Sep 05, 2014 7:02 pm
As a member recommended freeCAD i decided to give it go. It seems fairly easy to use however the stl output did not quite turn out as i expected. Anyone has any ideas?
view of STL in mattercontrol
Freecad bottom view
Freecad view
BidonKapak.stl
The STL file
(499.89 KiB) Downloaded 57 times
BidonKapak.FCStd
The Freecad File
(12.94 KiB) Downloaded 57 times
crocky
Re: stl output not quite as i expected
Post by crocky » Tue Sep 23, 2014 9:05 pm
None yet...
I have just loaded it :)
Bob
Delta's are the way!
crocky
Post by crocky » Tue Sep 23, 2014 9:32 pm
Same result as you I'm afraid.
Might be the way it is constructed, not much help :)
Bob
ULTIMATE 3D JEDDI
Post by Jimustanguitar » Wed Sep 24, 2014 1:13 am
Did you try running it through NetFabb? Sometimes there are problems with the export process (disconnected triangles and the such) that NetFabb can repair.
Provided that you're selecting the correct parts, and have the right features of your model "turned on", it's got to be something between the export and opening it in the slicing program.
Have you tried a different slicer, just to eliminate variables?
Another test could be to save as a "real" CAD file, open it with something else, and do the STL export with a second program. It's hard to speculate what will fix it, you'll just have to try a little bit of everything :)
teoman
ULTIMATE 3D JEDDI
Post by teoman » Wed Sep 24, 2014 3:09 am
It was my first try. And i did not try that part again. But i believe it wqs because i left some degrees of freedom on my bottom sketch.
Neofire
Post by Neofire » Thu Sep 25, 2014 1:18 pm
This is an old post but I wanted to answer the question in case anyone else has this problem.
The problem with the STL file is that the FreeCAD model hasn't been "fused" using the "Make Union of Several Shaps Tool" on the Parts workbench. Since it wasn't fused FreeCAD only exported the highlighted portion and not the entire model. I attached the fused and Re-Filled FeeCAD and STL files
BidonKapak v2.stl
STL File
(157.99 KiB) Downloaded 126 times
BidonKapak v2.FCStd
Fixed FreeCAD File
(19.16 KiB) Downloaded 148 times
teoman
ULTIMATE 3D JEDDI
Post by teoman » Thu Sep 25, 2014 4:55 pm
Thank you for that.
Return to “FreeCAD”
