HUGE FAIL - had to disconnect nozzle
TFMike
Re: HUGE FAIL - had to disconnect nozzle
Post by TFMike » Sun Mar 29, 2015 2:21 pm
Nylocke wrote:Is the output on the RAMBO actually supplying the heater with power? What are your heating settings (PID Max, P, I, D, Max PWM power, etc)?
max temp was changed from 247 to 290, min defect was -10, max defect was 300
pwm was 255
any other numbers you want me to screen shot in matter control?
Nylocke
ULTIMATE 3D JEDDI
Post by Nylocke » Sun Mar 29, 2015 2:54 pm
All the other heating variables, the max temps don't matter. Drive Max, PID Max, etc
TFMike
Post by TFMike » Sun Mar 29, 2015 3:19 pm
Nylocke wrote:All the other heating variables, the max temps don't matter. Drive Max, PID Max, etc
Too lazy to mess with screenshots in mattercontrol so here is the whole shebang in a .txt file
EDIT: On a side note, way back in 2013 when I got this I knew soemthing like this would happen, I just knew it. I was scared of ever having to mess with firmware/eeprom/gcode and all of that but now that I have had to tear down the nozzle and mess with the firmware I have found it isn't as bad as I had originally though, just wish it worked now :/
Nylocke
ULTIMATE 3D JEDDI
Post by Nylocke » Sun Mar 29, 2015 3:50 pm
The configuration file is irrelevant when talking about these values. They are overridden by EEPROM. Can you post a screenshot of your EEPROM settings.
TFMike
Post by TFMike » Sun Mar 29, 2015 4:18 pm
My mistake, also I accidentally uploaded the config file from the outdated firmware earlier so I deleted it to avoid confusion, this screencap here should have all the settings from the new upload:
Nylocke
ULTIMATE 3D JEDDI
Post by Nylocke » Sun Mar 29, 2015 4:54 pm
Those settings all look fine. Is the connector on the RAMBo actually delivering 12V to the hotend?
ULTIMATE 3D JEDDI
Post by Mac The Knife » Sun Mar 29, 2015 5:06 pm
Extr.1? Unless Mattercontrol is changing the labeling, Extr.1 is for a second extruder. Extr.0 is for the primary extruder.
TFMike
Post by TFMike » Mon Mar 30, 2015 1:53 am
Mac The Knife wrote:Extr.1? Unless Mattercontrol is changing the labeling, Extr.1 is for a second extruder. Extr.0 is for the primary extruder.
Ok, so could that be the reason? I am using the latest version for what it's worth.
Nylocke wrote:Those settings all look fine. Is the connector on the RAMBo actually delivering 12V to the hotend?
No idea, how do I check that?
Nylocke
ULTIMATE 3D JEDDI
Post by Nylocke » Mon Mar 30, 2015 2:52 am
Do you have a multimeter? Turn it on volt mode and touch them to the pos and neg
TFMike
Post by TFMike » Mon Mar 30, 2015 3:41 pm
It reads 11 or -11 depending on the orientation of the black and red
Nylocke
ULTIMATE 3D JEDDI
Post by Nylocke » Mon Mar 30, 2015 5:59 pm
11 exactly? Thats a bit low, but it shouldn't make too much of a difference. Have you checked the connection to make sure you have good continuity to the heater cartridge? What is the resistance of the heater cartridge? It should measure around 3.6 ohms if my math is correct (40 watt cartridge @ 12V, W=V*I, W/V=I, 40/12=3.33333A, V=I*R, V/I=R, 12V/3.33333A=3.6ohms).
TFMike
Post by TFMike » Mon Mar 30, 2015 10:44 pm
It's a 25 watt cartridge, but after all of that hullabaloo it was damn sloppy connection to it that led to all this, I just had a convo with JJ and touched my thermistor to my heater cartridge and told the printer to heat up and did....of all the reason for it to fail, that was why :/
predawnsky
Post by predawnsky » Sun May 03, 2015 6:23 pm
oh wow thats insane
