Ugly outline perimeters
dsl158
Postby dsl158 » Thu Jul 05, 2018 11:28 pm
Printing speed: 3200 min/mm
Outline Underspeed: 50%
Solid Infill Undnerspeed: 45%
Layer Height: 0.2300 mm
Temperature: 210C
Filament type: Pla
Retraction Distance: 5.60 mm
Retraction Speed: 7600.0 mm/min
Slicer: Simplyify3d
joe
Re: Ugly outline perimeters
Postby joe » Fri Jul 06, 2018 6:26 pm
Yup, those are ugly outline perimeters. Did you want me to tell you that you should ask a question?
dsl158
Postby dsl158 » Sat Jul 07, 2018 10:50 am
joe wrote:Yup, those are ugly outline perimeters. Did you want me to tell you that you should ask a question?
Hahahah sorry I was so frustrated I forgot to ask. Any ideas on how to fix it?
ULTIMATE 3D JEDDI
Postby Xenocrates » Sat Jul 07, 2018 11:44 am
I suspect it's partially that the speed is too high, and also that either the belts are not tight enough, or that there is backlash or slop somewhere in the setup. Make sure that your hotend is tightly connected to the effector, that the bed is not shifting, and that the carriages are in good shape.
joe
Postby joe » Sat Jul 07, 2018 7:01 pm
I would agree with some mechanical play, probably not your settings except for speed. Make sure everything is tight. Make sure your hotend itself doesn't have any play. Print again slow, make your adjustments at that speed, then once you have a good print try speeding it up.
What machine do you have?
dsl158
Postby dsl158 » Tue Jul 10, 2018 6:58 pm
joe wrote:I would agree with some mechanical play, probably not your settings except for speed. Make sure everything is tight. Make sure your hotend itself doesn't have any play. Print again slow, make your adjustments at that speed, then once you have a good print try speeding it up.
Rostock max v3
dsl158
Postby dsl158 » Sun Jul 22, 2018 6:17 pm
Would my noise dampeners have anything to do with this? I checked the belts and it seems as if there is a fine layer of belt dust everywhere and the motors are being pulled inwards due to belt tension. is there a way to tension my belts without the dampeners moving?
https://www.amazon.com/MatterHackers-Printer-Motor-Vibration-Dampers/dp/B00Q777UKS
joe
Postby joe » Sun Jul 22, 2018 9:35 pm
Dampers can have an effect. If you are getting dust and the motors are twisting you may actually have the belts too tight. This will cause binding and on a delta even one belt binding will cause grief.
dsl158
Postby dsl158 » Sun Jul 22, 2018 11:42 pm
joe wrote:Dampers can have an effect. If you are getting dust and the motors are twisting you may actually have the belts too tight. This will cause binding and on a delta even one belt binding will cause grief.
If i loosen it anymore it will slip
Who is online
