LCD Reseting and non navigable!
WiscoMudder
Postby WiscoMudder » Mon Jul 10, 2017 9:16 am
I have been having this issue for since the beginning. I've gotten 2 replacement LCD Screen controllers.
I can't navigate with white knob it will reset the screen, I can click in a few but can't go further. I'm told its a wiring issue on my end however my cheap eBay Prusa i3 screen hooks up and works flawlessly on my Rostock Max V3. Other then that my machine works fairly well. Considering its the dual extrusion set ups and randomly switches materials by itself.
Any idea's?
ULTIMATE 3D JEDDI
Re: LCD Reseting and non navigable!
Postby geneb » Mon Jul 10, 2017 10:54 am
The adapter board might be off by one pin to the left or right.
WiscoMudder
Postby WiscoMudder » Mon Jul 10, 2017 4:16 pm
I will check this, this evening. Its possible but If 1 cheaper eBay board works why wouldn't a similar one?
WiscoMudder
Postby WiscoMudder » Fri Jul 14, 2017 10:09 am
I made sure the adapter board was seated correctly, all fuses are fine, I refreshed back to single extrusion and my extruders don't work. Even after unplugging the E1 motor. LCD behaves the same way.
The boards look fine and no visible since of damage with a 10x magnifier.
Seriously puzzled.
W
WiscoMudder
Postby WiscoMudder » Tue Jul 25, 2017 11:33 pm
I even tried a board much like it off of amazon. Same results.
barry99705
Postby barry99705 » Sat Jul 29, 2017 9:03 am
Make sure the red wire points to the left as you look at the back of the screen. Sometimes the connector gets put on backwards.
WiscoMudder
Postby WiscoMudder » Wed Aug 02, 2017 6:51 pm
So far the wiring seems to be correct. I even ordered a replacement screen from e-bay and behaves the same way.
If I switch the wires around or flip positions nothing works at all on the screens. Is there anyway to test the board?
Jason
WiscoMudder
Postby WiscoMudder » Thu Aug 10, 2017 2:17 pm
The wire was backwards on my board. so now its fixed and working much gooder!
Thanks guys!
W
Who is online
Users browsing this forum: No registered users and 3 guests
