Trick Laser MAX METAL with Linear Rails
Such as Laser cutters (Must use the phrase 'sharks with frickin lazors' once per thread)
DerStig
Re: Trick Laser MAX METAL with Linear Rails
Post by DerStig » Sun Jun 12, 2016 4:56 pm
at what point did you increase the height? My frame shipped on 2/24, is it one of the longer frames?
bvandiepenbos
Post by bvandiepenbos » Sun Jun 12, 2016 6:56 pm
DerStig wrote:at what point did you increase the height? My frame shipped on 2/24, is it one of the longer frames?
Yours is the original 33" columns.
Taller revised frames started shipping first of this month, June 2016
DerStig
Post by DerStig » Mon Jun 13, 2016 4:24 am
can I get the taller columns?
bvandiepenbos
Post by bvandiepenbos » Mon Jun 13, 2016 12:09 pm
I machine the frame sides and columns together as sets. So, no I do not sell the columns separately. Sorry.
Fishbyte
Post by Fishbyte » Sun Jul 03, 2016 10:41 pm
Apparently this thread is no longer active? I hope MHackney is in good health and he is just too busy to revert back to this build. My best goes out to him and I will continue with my metalmax build. I was hoping to follow along his trials and tribs to help educate me.
Windshadow
Post by Windshadow » Sun Jul 03, 2016 10:45 pm
I asked after him a while back but there has been no news... perhaps he is just busy with it being the fishing season
Fishbyte
Post by Fishbyte » Sun Jul 03, 2016 11:21 pm
I hope and pray that is the case and that he is not falling out of love with the 3d printing obsession. He is involved in sooooo much stuff that he may of had a mental and physical breakdown :o Let's hope not.
jmpreuss
Post by jmpreuss » Mon Jul 04, 2016 1:19 pm
Fishbyte wrote:I hope and pray that is the case and that he is not falling out of love with the 3d printing obsession. He is involved in sooooo much stuff that he may of had a mental and physical breakdown :o Let's hope not.
For those who have been following this forum for a long time know that MHackney participation is seasonal, there are certain times of the year he has no available time because of his businesses that pays the bills. I'm sure he'll be back at some point.
626Pilot
ULTIMATE 3D JEDDI
Post by 626Pilot » Sat Jul 09, 2016 6:49 am
Windshadow wrote:I asked after him a while back but there has been no news... perhaps he is just busy with it being the fishing season
A good thing to be busy with!
Nylocke
ULTIMATE 3D JEDDI
Post by Nylocke » Sat Jul 09, 2016 11:49 am
He posted on the DuetWifi forum about him replacing his old duet on his main V1 with a DuetWifi just yesterday.
https://www.duet3d.com/forum/thread.php?id=54
ULTIMATE 3D JEDDI
Post by mhackney » Sun Jul 10, 2016 10:50 pm
I'm trying to be more consistent here but May/June are extremely busy months on all sorts of fronts. But I'm back now - a much shorter hiatus than years in the past.
This build has been stalled due to lack of time. I have a couple of other projects - like beta testing the new Duet WiFi - and then I will pick this up again.
rubiks24
Post by rubiks24 » Tue Jul 19, 2016 1:36 am
mhackney wrote:Fishbyte, I sent you an email about the parts. You actually need top and bottom brackets with idlers to offset the belt (see the previous page of this thread) and you need to modify the slots down by the steppers to provide clearance for the idlers. If there is interest from others I can make a few sets of these parts.
I been following this thread for a while now too, just curious if you ever got around to making those brackets. I would be very interested in a set. I am in MA too. Thanks!
ULTIMATE 3D JEDDI
Post by mhackney » Tue Jul 19, 2016 12:32 pm
I'm making a set for another gent. Where are you in MA? (pm if you prefer)
rubiks24
Post by rubiks24 » Tue Jul 19, 2016 3:27 pm
mhackney wrote:I'm making a set for another gent. Where are you in MA? (pm if you prefer)
pm sent, thanks! By the way, are you thinking about making the TrickLaser carriage arm mounts out of aluminum? Seems like something reasonably easy to water jet cut out of 3/16 sheets of aluminum and then tapped (I might still be able to get those done if you like a set). I suppose the belt attachment and tensioning mechanism can be CNCed but not sure if thats worth the effort?
edit: actually just spoke with my waterjet cutting guy and he will whip up a couple sets of the carriage arm mounts this week for me, I'd be happy to send you a set. I sent him a DWG drawing based on your STL (modified the alignment hole size a little according to Brian's trick truck CAD drawings).
ULTIMATE 3D JEDDI
Post by mhackney » Fri Oct 07, 2016 9:43 am
Well, after this project stalled due to time constraints primarily I'm picking it up again. However, I did get far enough with my build to realize that the linear rails are going to eat into my build diameter by about 2", so a 10" build diameter (max and I think it might end up being smaller than that). That didn't sit well, I need the space to print multiple parts at once.
Then along comes Brian and TrickLaser's new Trick Truck X Mini Carriages and new ball-cup CF arms and matching effector. These will accelerate completing this machine and provide basically a "assemble from existing parts" solution that might be more appealing to folks wanting a state of the art, rigid delta printer.
Here are the new parts:
So the new Max Metal project will consist of:
  • Max Metal frame
  • .8° steppers for motion
  • all new TrickTrucks, CF Ball-Cup Arms, platform
  • DuetWifi
  • 7" PanelDue
  • 24V Meanwell power supply
  • two Bondtech extruders
  • E3D Systems Cyclops hot end (dual mixing hot end)
  • Onyx heated bed
  • FSR bed leveling (primarily because Duet firmware does not support the accelerometer probe yet, but I am going to mount an extra PCB so I can start working on that)
ULTIMATE 3D JEDDI
Post by mhackney » Fri Oct 07, 2016 4:45 pm
I couldn't wait to get started, these parts sitting on my desk were like a Siren calling "build me, build me". I took off the linear rails and my custom offset belt guides, carriages and tensioners. Once I had the Max Metal down to it's stock frame, assembly of the new Mini X Trick Trucks, Ball Cup Arms and plate took 6 minutes. And boy are these parts beautifully machined and those red ball cup ends are the perfect bling!
ULTIMATE 3D JEDDI
Post by mhackney » Mon Oct 10, 2016 8:19 pm
I really like the simple belt attachment on the new carriages Brian, bravo1
bvandiepenbos
Post by bvandiepenbos » Tue Oct 11, 2016 9:04 am
mhackney wrote:1475731359811-867362821.jpeg
I have been trying different things for almost a year, but was never satisfied with anything.
Until one day recently I had a "Ah ha" moment... this design I am pleased with.
626Pilot
ULTIMATE 3D JEDDI
Post by 626Pilot » Tue Oct 11, 2016 3:27 pm
Does this mean you're done with the linear rails forever?
ULTIMATE 3D JEDDI
Post by mhackney » Tue Oct 11, 2016 4:53 pm
No. But I will likely design using them as the tower itself so I don't sacrifice print area. I have linear guides on one of my mini kossels and it is the quietest and most precise delta I have. I'm also using these same rails on a new Core XY I'm trying to build with a 24" x 12" x 18" build envelope.
ULTIMATE 3D JEDDI
Post by mhackney » Mon Oct 17, 2016 8:22 pm
I have a new design for an FSR base plate that moves the FSRs out from the bed perimeter to minimize/eliminate any rocking movement when probing between FSR mount points. It looks like this:
The FSRs will be located under the apexes (red). A Delrin plunger is mounted to the underside of the plate and a milled brass holder with the FSR in it will be mounted to the Max Metal frame at the tower vertex.
Now I need to find a laser to cut the thing out!
Return to “Other Machines”
