626Pilot wrote:You can reuse the steppers, pulleys (if they're the new 20-tooth ones from SeeMeCNC), hobbed drive gear, EZ-Struder, T-slot nuts, power supply, power switch, GT2 belts, binder clips, Onyx + glass, PTFE tubing, endstop switches, controller, and LCD panel. You can also leave out the paracord unless you're doing a flying extruder platform. The John Guest connector is the standard E3D PTC fitting, although they drill it out so you can pass the PTFE all the way through.
You also need a bunch of 3D-printed parts. The git repo is here.
Oh no, when did seemecnc switch pulleys, if they did at all?
EDIT: I built a rostock max v2 about a year ago and I used the 2nd edition of gene's guide to do so. Here is what it says about the pulley at the beginning:
(1) GT2 2mm pitch belt pulley pack. Includes six grub screws
and hex wrench. [39835]
