Ebay Lasers
Such as Laser cutters (Must use the phrase 'sharks with frickin lazors' once per thread)
KAS
ULTIMATE 3D JEDDI
Ebay Lasers
Post by KAS » Wed Jun 01, 2016 9:57 pm
Anyone have experiences with the Redsail 50w / 6ow clones being sold on ebay? I know the wattage is overstated from the reviews I can find, but nobody seems to have any real issues.
I don't mind upgrading after the fact, just want something with a larger footprint to learn on. $2k-ish is about my budget.
something like this: http://www.ebay.com/itm/291411058723?_t ... EBIDX%3AIT
ULTIMATE 3D JEDDI
Re: Ebay Lasers
Post by geneb » Thu Jun 02, 2016 9:27 am
LASE ALL THE THINGS!!!!111ONEONEONE :D
Looks like a nice rig.
jram
Re: Ebay Lasers
Post by jram » Sat Jun 04, 2016 12:09 am
I'm interested in seeing how this works out if you get it. I'm in the market for one in that price range or a bit above and I'd really like to hear some firsthand feedback on this machine.
Captain Starfish
Re: Ebay Lasers
Post by Captain Starfish » Sat Jun 04, 2016 12:36 am
A lot of feedback on this brand and its shadier copies coming out of China can be found on cnczone. Sorry, never paid much attention but I see the name in the thread titles all the time there.
ULTIMATE 3D JEDDI
Re: Ebay Lasers
Post by Eaglezsoar » Sat Jun 04, 2016 10:41 am
Does anyone know how deep into mdf this machine could cut?
ULTIMATE 3D JEDDI
Re: Ebay Lasers
Post by Xenocrates » Sat Jun 04, 2016 11:00 am
If it's actually a 60W machine, ~1/4 inch at reasonable speeds. However, as KAS mentioned, the machines are over-advertised on wattage.
If I may make a suggestion, while the footprint is slightly lower (20X12), the company that made my laser has an actual 50W one for ~2K. I had precisely one problem with mine (The tubing for the air compressor wouldn't fit on the bayonet, but the threading on it was unusual enough I couldn't find a properly sized replacement, so I had to make up a bridge with some larger tubing, and a pair of bayonets threaded together). http://www.automationtechnologiesinc.com/products-page/laser-engraving/50wlasermachine
If you have a bit more budget they have a 60W model for only 600 more. They also have rotary attachments and other things you can add on. The nicest thing is that they pack in the chiller, exhaust blower, compressor, and most of the tubing and fittings required (Ours included a very large resistor for dummy load testing, and a fairly tough if quite small flash drive (The flash drive needs to be small in size for the controller to recognize it, if it's the same controller as ours. we have good luck with ~110MB drives, which are easily available online still, and you can fit plenty of MOLs on it), the only thing we needed they didn't pack in was distilled water and the fittings for the bridge I had to make)
Biggest downside is the lasercut software. It's got a poorly translated Chinese manual, and is a little crash happy. But it works once you figure it out (Hint, Soft dog is a Software Dongle)
ULTIMATE 3D JEDDI
Re: Ebay Lasers
Post by Eaglezsoar » Tue Jun 07, 2016 3:45 pm
Thanks for all of this info about lasers and the source for the laser that you have experience with.
Can the 50 Watt cut 1/4" into the mdf as well as the Ebay Chinese versions? You are a wealth of information!
Xenocrates wrote:If it's actually a 60W machine, ~1/4 inch at reasonable speeds. However, as KAS mentioned, the machines are over-advertised on wattage.
ULTIMATE 3D JEDDI
Re: Ebay Lasers
Post by Xenocrates » Tue Jun 07, 2016 4:01 pm
If anything, it should cut better. It should come with a chiller that will keep liquid temps relatively low (~15C is my experience), which allows the lasing tube to develop more output at a given power level, and is an actual 50W tube, while the redsails are apparently optimistically rated at 50Ws. My machine, which is the larger 60W 24X16 (The area you can use is actually larger than that, miracle of miracles), has an 80W power supply and a 60W tube. I suspect that the 50W machine will come with a 50W tube and a 60W power supply, given their usual modus operandi. Or you could pay the premium to get a 60W tube from the outset.
However, cutting power is dependent on the optics more than much else. The laser, while having some level of auto-focus, usually keeps the focal point right at the depth probe. It also likely will not arrive fully aligned, so make use of the spotting laser to help you align it.
You will have to cut somewhat slowly though. We cut 1/4 baltic birch and mellamine on our laser routinely, and it is a bit slow at that. With ~85% of the power, you'll probably need 85% of the speed we use (And unfortunately, the lasercut control's don't tell us MM/s or wattage or duty cycle, so it's a real guessing game figuring out what they mean. They could be in Becquerels per Dioptere for all I know)
ULTIMATE 3D JEDDI
Re: Ebay Lasers
Post by Eaglezsoar » Tue Jun 07, 2016 4:44 pm
Thanks Xenocrates!
Return to “Other Machines”
