MAX METAL poll -build right or upside down?
Such as Laser cutters (Must use the phrase 'sharks with frickin lazors' once per thread)
How are you building your machine, "normal" or "upside down"
Normal (motors, electronics, lcd & psu on bottom)
8
47%
Upside Down (motors, electronics and lcd on top, psu on bottom)
9
53%
Other
0
No votes
Total votes: 17
bvandiepenbos
Postby bvandiepenbos » Thu Apr 28, 2016 9:34 am
How are you building yours?
miglo
Re: MAX METAL poll -build right or upside down?
Postby miglo » Thu Jun 16, 2016 10:23 am
Opting for "normal style". I don't want my printer to be top heavy.
bob64
Postby bob64 » Mon Jun 20, 2016 1:12 am
If you mount your power supply to the base, that'll solve the "top heavy" problem.
Rostock Max V2 with mods:
E3d v6 with 713maker mount & e3d titan extruder
Tricklaser CF arms, heat spreader, tricktrucks, fly-n-strude, metal carriage & effector
Duet v.8.5.0
24v MeanWell 750w PS & Cydom D1D40 SSR in parallel with stock 12v PS
miglo
Postby miglo » Tue Jun 21, 2016 11:10 am
I ended up moving the PSU completely outside the enclosure bc prevent overheating.
What's the advantage of flipping it upside down?
Update:. Ah I guess it would make wiring easier. Too late now.
626Pilot
ULTIMATE 3D JEDDI
Postby 626Pilot » Tue Nov 15, 2016 9:42 pm
I ran some of the Trick Laser 8-conductor wire up one of the insides of the channels. That takes care of the endstops. For the hot end wiring, I use a cable mast: http://www.thingiverse.com/thing:1554882
Return to “Other Machines”
Who is online
