Filament orientation
LAFilament
Postby LAFilament » Thu Nov 19, 2015 10:53 pm
I thought I remembered seeing somewhere that the filament should be oriented with the feed coming over the top of the spool as the best way to do it if you are routing it as per the instructions
Am I remembering correctly?
Thanks,
Mo
[url]LAFIlament.com[/url]
ULTIMATE 3D JEDDI
Re: Filament orientation
Postby Jimustanguitar » Thu Nov 19, 2015 11:48 pm
Whichever way feeds the filament at the straightest angle is the right choice. Other than that, it doesn't really matter. I feed mine over the top.
LAFilament
Postby LAFilament » Sat Nov 21, 2015 11:55 am
Thanks. I think the tension on the extruder spring is a bit low.
LAFilament
Postby LAFilament » Sun Nov 29, 2015 2:55 pm
forgot to post an update -
The problem that I was having was that it seemed like the printers were starving.
The screw for the tension release was loose. Tightened 'er back up and we're good to go.
Return to “ORION”
Who is online
