Peek fan replacement
Vic
Post by Vic » Sat Nov 14, 2015 3:41 pm
The Peek fan on my Orion appears to be sick. I would like to get a replacement 25 mm fan. What is a good quality (and quiet) fan that has been used. Doing a search of the forum I found this: Top Motor DF122510BL-3G
But it appears to use 3 wires not 2 like the Orion. I want to simply swap it out without having to modify what I have.
Thanks
Vic
Re: Peek fan replacement
Post by Mac The Knife » Sat Nov 14, 2015 4:04 pm
The third wire, (white), is for temperature reading, so all you would need to use is the black and red wires.
Vic
Post by Vic » Sat Nov 14, 2015 5:07 pm
Great. Thanks!
teoman
Post by teoman » Sat Nov 14, 2015 5:34 pm
I remembersome stls to fit 4mm fans on there but cannot find any.
Yesterday my fan also died. Anditwill take a while to getthe replacement.
Post by geneb » Sat Nov 14, 2015 11:22 pm
Just FYI, the third wire on fans is for RPM, not temperature. :)
Post by Mac The Knife » Sun Nov 15, 2015 11:29 am
geneb wrote:Just FYI, the third wire on fans is for RPM, not temperature. :)
I guess they're yellow for temperature? Since its for reading rpms, I'm surprised someone hasn't tried using the signal for a failsafe of some kind.
Post by Eaglezsoar » Sun Nov 15, 2015 2:30 pm
A lot of computer motherboards do use the RPM wire from the fan as a failsafe. I am not sure if any of the 3D firmware does it but I doubt it because every
fan I have seen throughout the various printers are all 2 wire.
Return to “ORION”
