Print quality is just about perfect -- w00t!!
michaellatif
Post by michaellatif » Mon Mar 26, 2012 11:54 pm
I think I have slic3r and Repetier firmware/host tuned in to almost perfect values.
Here is my latest print (kinda geeky :mrgreen:)
Klingon Insignia (1)
Klingon Insignia (2)
Klingon Insignia (3)
Klingon Insignia (4)
I will create a post in the Sanguino area for settings/values.
Mike Latif
H-1 #3
Chris Muncy
Re: Print quality is just about perfect -- w00t!!
Post by Chris Muncy » Tue Mar 27, 2012 10:59 am
Hmmm very nice! Now time for a Federation emblem!
Chris Muncy
H-1 #5
Geirhart
Post by Geirhart » Tue Apr 03, 2012 10:12 am
Geeky is Cool
Chris Muncy
Post by Chris Muncy » Tue Apr 03, 2012 10:17 am
Michael,
Time to print this: http://www.thingiverse.com/thing:20674
[If you don't know what this is]
Aperture Science
Chris Muncy
H-1 #5
Geirhart
Post by Geirhart » Tue Apr 03, 2012 4:00 pm
It has to be a part of your own mini stargate.
G
Chris Muncy
Post by Chris Muncy » Tue Apr 03, 2012 4:03 pm
Chris Muncy
H-1 #5
michaellatif
Post by michaellatif » Wed Apr 04, 2012 12:07 am
Challenge accepted!
First picture is when the print was about 60% complete, second is of a quickly cleaned up print.
Not bad for first attempt with my default settings in slic3r.
Mike Latif
H-1 #3
seemeadmin
Site Admin
Post by seemeadmin » Wed Apr 04, 2012 8:26 am
Ok, I'm going to have to add a Nerd Badge to the "ranks" cause you guys are definately rockin it!
Geirhart
Post by Geirhart » Wed Apr 04, 2012 8:57 am
I make no addmission on my nerddom:] But that is going to be a very cool stargate for G.I. Joe.
G
cquinby
Post by cquinby » Wed Apr 04, 2012 10:45 am
seemeadmin wrote:Ok, I'm going to have to add a Nerd Badge to the "ranks" cause you guys are definately rockin it!
Good thing the Star Trek communicator badge would not print uhhhhh.... for my wife....
http://www.thingiverse.com/thing:14345
Can anyone print this? I tried Slic3r but get manifold errors and only partial gcode. I tried to fix it in Netfab but no luck.
__
Chris
michaellatif
Post by michaellatif » Wed Apr 04, 2012 10:49 am
I couldn't get that one to print, I however printed the following one:
http://www.thingiverse.com/thing:1209
Mike Latif
H-1 #3
cquinby
Post by cquinby » Wed Apr 04, 2012 11:19 am
Cool... I will try that one after I test a new spacer designed for 608 bearings to 1/4 rod for my spool adapters.
__
Chris
ALeander
Post by ALeander » Wed Apr 04, 2012 12:31 pm
Try this file:
TNGCommunicator3thick_fixed.stl
(34.36 KiB) Downloaded 45 times
I ran it through netFabb to correct any manifold issues and it now slices perfectly.
Anthony
Anthony Leander
Running the Creeper Creator
Chris Muncy
Post by Chris Muncy » Wed Apr 04, 2012 12:38 pm
I guess I am going to have to download Netfab and keep that handy as I have a few things I want to print that have the same issue.
Chris Muncy
H-1 #5
ALeander
Post by ALeander » Wed Apr 04, 2012 12:52 pm
They have a nice cloud based service that I used if you don't want to bother with learning a new program.
Simply upload your file and then download the fixed one.
Nice and easy.
Anthony Leander
Chris Muncy
Post by Chris Muncy » Wed Apr 04, 2012 1:07 pm
ALeander wrote:They have a nice cloud based service that I used if you don't want to bother with learning a new program.
Nice and easy.
Very cool!
http://cloud.netfabb.com/
Chris Muncy
H-1 #5
michaellatif
Post by michaellatif » Wed Apr 04, 2012 1:30 pm
Nice and easy.
Very cool!
NICE!! I have a few items that I want to print but ran into manifold issues during slicing.
Mike Latif
H-1 #3
johnoly99
Post by johnoly99 » Thu Apr 05, 2012 7:49 am
Hey guys, another thing we've noticed with some .stl files not slicing easily, check your drawings units! I keep replicatorG around and handy now, because it's an awesome way to open your stl file and see where it is in relative position, rotate it, scale it, then save it. We've found quite a mix of metric and imperial drawings on the web. If you try and slice a file drawn in inches, slic3r gives errors usually. When you use slic3r and set the scaling to 25.4, it slices!
Chris Muncy
Post by Chris Muncy » Thu Apr 05, 2012 11:04 am
I've noticed that too. If I have issues I open it up in ReplicatorG, convert Inch to mm, save it, slice it with Slic3r, and I'm good to go.
Chris Muncy
H-1 #5
