A debut of my new Yellow Jacket build.
Jassper
Post by Jassper » Sun Apr 10, 2016 8:59 pm
A quick video of my new build (actually a crappy video - my phone doesn't do video very well)
Frame: Tricklaser MAX Metal
Electronics: FastBot 3D BBP 1 from their Kickstarter
Motors: 0.9 400 steps
Hotend: E3D Light with Tricklaser platform and 713Maker mounting and Yellow Jacket plug in board.
Heated Bed: 120 Volt electric stove coil mounted to a 3/8" aluminum plate
Custom Carbon Fiber Arms and Trucks I cut out of G10 FR4 fiber board with the Shapoko II
https://youtu.be/5iXUGi1ELUw
The MakerHive
Berd-Air Cooling Kit
The MakerHive Store
teoman
Re: A debut of my new Yellow Jacket build.
Post by teoman » Mon Apr 11, 2016 2:27 am
Looks very good.
Mind writing a quick tutorial for the BBP?
Oh and how did you get the towers black?
Jassper
Post by Jassper » Mon Apr 11, 2016 7:31 am
teoman wrote:Looks very good.
The towers are simply Black anodized, special request. I sent the materials to Tricklase for the MAX metal frame.
http://www.fastbot3d.com/
http://wiki.fastbot3d.com/
I have been working close with Fastbot the past few weeks, they are dedicated to making their software the best it can be.
The MakerHive
The MakerHive Store
stonewater
Post by stonewater » Mon Apr 11, 2016 10:48 am
Jassper,
that is fantastic!! love the whole thing, color is amazing!!!
Tom C
MAX V1
Corvair750
V6 Hotend
Robo 3D
Flashforge creator
Post by Eaglezsoar » Mon Apr 11, 2016 12:40 pm
It's been said before but I must say it again - A Fantastic Printer!
On the cross pieces, did you have to use a special primer before painting them yellow?
Jassper
Post by Jassper » Mon Apr 11, 2016 2:41 pm
Eaglezsoar wrote:It's been said before but I must say it again - A Fantastic Printer!
According to everything I read on the internet - no. But this is one of those times I wish I had followed my gut. Supposedly aluminum that is already anodized (clear), doesn't need any special primer to get paint to stick. But I am noticing paint peeling already. So I will most likely take one rail off at a time (top and bottom) strip it and use acid etch primer first, then re-paint. :(
The MakerHive
The MakerHive Store
Post by Eaglezsoar » Tue Apr 12, 2016 6:18 pm
Thank you for what you said. I thought aluminum anodized or not required acid primer and you just made sure that I do not make the same mistake, thanks!
ccavanaugh
Post by ccavanaugh » Tue Apr 12, 2016 6:36 pm
The typical anodizing process uses a seal process which improves corrosion resistance and protects against staining. You can request a cold water rinse that won't seal and then provides a good layer for paint adhesion.
It's not something you will get unless you work directly with the anodizing supplier.
Post by Eaglezsoar » Tue Apr 12, 2016 6:40 pm
That explains it wonderfully, thanks!
Jassper
Post by Jassper » Tue Apr 12, 2016 9:24 pm
Would using a #0000 steal wool on the piece first remove this seal?
Perhaps I'll do both SW and acid primer. Thanks for the info.
The MakerHive
The MakerHive Store
ccavanaugh
Post by ccavanaugh » Wed Apr 13, 2016 4:47 am
No... to seal in the anodizing world is to close down the porous structure. It would take a chemical strip and anodizing process at that point. A good shop can strip, and then I would do with a Type III hard anodize over the Type II they came with. Much harder, slicker, and thickness can be increased to offset the lost thickness from removal of the Type II. Type III will be a darker grey and most shops will be able to add a black dye.
blainet
Post by blainet » Sun Jan 01, 2017 3:57 am
Sorry to bring back up this older thread. One note on hard coat anodizing. Half of the anodizing is into the metal and half on top. Think that it will add .0015" or less to your finished surface so a slot that's say .200" wide will be reduced by .0015" per side, total of .003" or less. Probably not something you would notice. Stripping can remove more than that if they aren't careful and the piece must be brought back to bare metal for anodizing to take. It's also a 'line of sight' process so the inside of a tube will get little to none of the coating. Hard coat is also not conductive - an ohm meter should show zero whereas decorative anodizing will be conductive and is much thinner. Ccavanaugh is correct - hard coat has a very high hardness rating and depending on the application, can be grown into thicknesses of .005" or greater.
Bbegent
Post by Bbegent » Sun Jan 15, 2017 10:22 pm
Love the arm design with springs. Im using rubber bands and dont think its a good longterm choice.
Unleash your Creativity
