Sculptris by Pixologic
http://pixologic.com/sculptris/
PartDaddy
Postby PartDaddy » Wed May 01, 2013 9:43 am
I was searching for sculpting software recently and found Sculptris. The software is here: http://pixologic.com/sculptris/
Very intuitive and fun. To print something you create, export the .OBJ file, then open the .OBJ using Slic3r. After scaling and orienting, you can export the .STL. Finally, open the .STL in Repetier and process as usual.
~PartDaddy
SeeMeCNC Owner & Founder
Since 1996
Island3
Re: Sculptris by Pixologic
Postby Island3 » Wed Jun 12, 2013 12:15 am
Heyyyyy this is very cool!! It's perfect for us visual folks.
LorenOlepi
Postby LorenOlepi » Mon Sep 09, 2013 12:43 pm
Yeah this software is awesome... use it to touch up/modify my 3d Scans ;)
Print_This
Postby Print_This » Mon Apr 28, 2014 12:35 am
very cool, i actually used it export it, and import into autodesk print utility and it repaired it and then just exported out as stl from there. have to spend more time on it! :)
If you survive chicago winters you can survive 3d printing!
Return to “Sculptris”
Who is online
