Repetier in Linux
Talk about the Repetier Host software here (http://repetier.com)
theverant
Repetier in Linux
Post by theverant » Tue Jul 23, 2013 7:18 pm
Having issues with Repetier Host in Linux - anyone using RH in a *buntu environment?
- I ran the script and it downloaded and installed tons of stuff. RH boots fine.
- I set up the printer as I did in the Mac version
- I lowered the baud rate as suggested in the firmware
- Arduino has no trouble connecting to the Rambo to upload firmware, so I know what the address is
- RH hangs when connecting with 6 commands queued
- Crashes if I click the protocol dropdown menu (it is set to serial)
- Seems to reset the printer address among other settings in the first printer setup tab
- has exactly the same weirdness on two completely different machines (One is Ubuntu, one is Linux Mint)
Am I missing a step?
:shock:
ULTIMATE 3D JEDDI
Re: Repetier in Linux
Post by geneb » Wed Jul 24, 2013 11:49 am
Are you using the 0.90c version of RH?
kbob
Post by kbob » Thu Jul 25, 2013 4:44 am
Sounds like baud rate to me.
In RH, do you see any messages from the printer when you connect to it? You should see something like this.
  1:43:38 AM: Attempting to connect to printer
  1:43:38 AM: Connection opened
< 1:43:47 AM: start
< 1:43:47 AM: FIRMWARE_NAME:RepetierMAX0.80 FIRMWARE_URL:https://github.com/seemecnc/RepetierMAX PROTOCOL_VERSION:1.0 MACHINE_TYPE:RostockMAX EXTRUDER_COUNT:1 REPETIER_PROTOCOL:2
< 1:43:47 AM: Printed filament:94.67 m
< 1:43:47 AM: Printing time:0 days 18 hours 4 min
(Note the time stamps. There is a 10 second pause in there.)
theverant
Post by theverant » Sat Jul 27, 2013 10:49 am
kbob wrote:Sounds like baud rate to me.
< 1:43:47 AM: start
I am using the latest version, yeah.
No, it just hangs. And I did turn down the baud rate in the firmware, and matched it in RH.
theverant
Post by theverant » Wed Jul 31, 2013 9:45 am
Tried it again, and it now works. I think this was related to the f'd up firmware/eeprom problems I was having. Thanks for the feedback, all!
:mrgreen:
Return to “Repetier Host”
