Slicer errors?
Slicer errors?
Post by Jimustanguitar » Sat Apr 27, 2013 5:47 pm
Has anybody else gotten this error while using the Slic3r built into Repetier Host?
Durandal
Re: Slicer errors?
Post by Durandal » Tue May 14, 2013 2:31 pm
I got this error when I turned the nozzle Diameter down to .1mm.
foshon
Re: Slicer errors?
Post by foshon » Tue May 14, 2013 4:01 pm
Yeah, slic3r failed, but RH is not programmed to pick that up.
Purple = sarcasm
summyman
Re: Slicer errors?
Post by summyman » Sat Jan 04, 2014 5:32 pm
I just updated to the newest version of Repetier Host, VO.95D and I get this same error message when I try to slice with Slic3r. Did you figure out how to resolve this error? Any help will be appreiciated.
SDI
Re: Slicer errors?
Post by SDI » Sat Jan 04, 2014 6:45 pm
i was offered the RH update today and declined due to my deep set, inherent fear of updates
JolietDelta
Re: Slicer errors?
Post by JolietDelta » Mon Jan 06, 2014 8:46 pm
Hi!
I get this message after provoking an error in slic3er. Seems that RepHost has changed its kind of error handling. The faulty part isn't RepHost but a unsuccessfull slic3r session.
Strange: objects/settings which couldn't be sliced with the command-line edition of slic3r (which is used by RepHost), didn't fail with the UI-version of slic3r.
Besides that - I had no problems after updating RepHost.
-Jens
foshon
Re: Slicer errors?
Post by foshon » Tue Jan 07, 2014 5:39 pm
I get it now that I've updated, yet Slic3r works very well. It's an integration issue of some kind. The cool kids are talking about it Repetiers Reprap forum sub-section.
Purple = sarcasm
Return to “Repetier Host”
