Loose arm upgrade
jesse
Loose arm upgrade
Post by jesse » Mon Aug 11, 2014 5:02 pm
My Rostock v1 arms are pretty loose. They've been used for about 50 total days of printing.
Is there an upgrade/replacement kit to get rid of the slack?
1ggy
Re: Loose arm upgrade
Post by 1ggy » Mon Aug 11, 2014 5:42 pm
I used rubber bands on mine. I use a pair for each set of arms, and have them placed right where the truss structure on the arm meets the U.
bvandiepenbos
Post by bvandiepenbos » Mon Aug 11, 2014 6:49 pm
the rubber bands may help a little bit, but not much since the joints are not spherical rod ends.
The Carbon Fiber Tube Arms from Trick Laser will solve the problem...
http://www.tricklaser.com/Carbon-Fiber- ... M-CFTX.htm
Return to “Rostock MAX”
