elqisqeyano
Postby elqisqeyano » Sat May 11, 2013 12:01 pm
cambo3d wrote:need someone to 3d print this project for me since my machine is currently down. who can help?
What do you need? I can try my best to help.
elqisqeyano
Postby elqisqeyano » Sat May 11, 2013 1:28 pm
What you think? You have more experience than me on this 3D printing. I trust your judgement.
elqisqeyano
Postby elqisqeyano » Sat May 11, 2013 1:32 pm
I would be interested in an aluminum version of the effector that I can attach the balls to instead of using ABS. Due to the fact that I will most likely be printing at high temps. Could you provide me with an aluminum effector for this magnetic system? I would pay you for it.
cambo3d
Postby cambo3d » Sat May 11, 2013 1:54 pm
pmed you, so we dont hijack this thread
Broose
Postby Broose » Sat May 11, 2013 2:12 pm
bplemmons wrote:Anyone have some before and after, print quality pics to share?
You can post them on what are you making...
Love to see them!!
Bill
Not quite perfect, but a big improvement. Click to zoom in. The rough part on the stock arms side I believe was where the loop starts after a retraction and move. Kisslicer staggers the start point on each layer. The other side of the Vica sculpture looks great on both prints.
EDIT:I've replaced the photo because on further inspection, the issue with the rough part on the stock arms print may have been retraction-related rather than an arm issue. The quality of the print is much improved with the magnetic arms, and this updated photo is a better comparison of print quality. Notice the better layer alignment on the magnetic arms version, which was actually printed faster.
elqisqeyano
Postby elqisqeyano » Sat May 11, 2013 4:29 pm
Love to see them!!
Bill
That is a noticeable difference. Did you see the one I printed with stock arms, came out close to yours with the stock arms. I can't wait for my CF tubes to arrive.
Broose
Postby Broose » Sat May 11, 2013 4:53 pm
Love to see them!!
Bill
I noticed after the print that one of my cheapskates was a little loose. That could account for the few imperfections that are left in the print with the magnetic arms. I won't have access to my printer until tomorrow, and I'll try another print then.
elqisqeyano
Postby elqisqeyano » Sat May 11, 2013 5:04 pm
Check those cams, make sure they are tight. I had the same problems cause I forgot to tighten down the Cams. Once tight cheapskates were firm, no wiggle.
bplemmons
Postby bplemmons » Sat May 11, 2013 9:51 pm
Broose, Nice work, What arms are you using?
sheepdog
Postby sheepdog » Sat May 11, 2013 10:14 pm
This is a fantastic mod from the pictures I have seen, excellent job.
xnaron
Postby xnaron » Sat May 11, 2013 11:03 pm
Love to see them!!
Bill
Looking good! What hot end are you using?
xnaron
Postby xnaron » Sat May 11, 2013 11:06 pm
Here are some pics of my new quick change extruder setup...
I'm using a 5.2:1 geared nema 17. I am set to 60mm/s retracts and the Rambo current is set at 115. I think I can go even faster on the retracts. To change the filament you just push the two long springed screws down and pull the bearing piece forward. It is super quiet! These are the extruders I use on all my other printers like the Behemoth. A little pricey though as the stepper and gear are about $50 to $60. For me it is well worth the price. I have hundreds of hours of use on these and they just keep on going and going.
In the pics you can see I put the hole in the wrong spot for the bowden tube on the laser cut piece. Doh!
The files are up on my github https://github.com/xnaron/Xnaron-Magnarms-for-Rostock
xnaron
Postby xnaron » Sat May 11, 2013 11:37 pm
Here is a vica I sliced with KISS at .25mm layer height in Vase fill with one loop. I am getting ever so slight stringies because I have the temp a touch low. This is with the cheap reprapper.com silver PLA. It doesn't print anywhere as nice as the ultimachine silver does.
Checkout the layer alignment! These delta's are amazing!
xnaron
Postby xnaron » Sun May 12, 2013 12:01 am
FYI
bplemmons
Postby bplemmons » Sun May 12, 2013 3:27 am
Wow, that extruder looks amazing. you are really taking the Rostock to a new level..
Can you share your source for the stepper?
Thanks for sharing your amazing upgrades!!
Bill
Postby Eaglezsoar » Sun May 12, 2013 4:58 am
Xnaron: Please read your PM's.
Broose
Postby Broose » Sun May 12, 2013 9:00 am
Love to see them!!
Bill
I'm using an E3d all metal hot end with a .4mm nozzle
xnaron
Postby xnaron » Sun May 12, 2013 5:10 pm
Because there are too many Yoda's...
Printed at 200mm/s in 45min. It is 100mm high.
Postby Eaglezsoar » Sun May 12, 2013 7:00 pm
Xnaron: Would it be possible for you to post the squirrel cage fan mounts that you created to hold those squirrel cage fans
you are using?
elqisqeyano
Postby elqisqeyano » Sun May 12, 2013 7:24 pm
xnaron wrote:Because there are too many Yoda's...
Wow.
CosplayEngineer
Postby CosplayEngineer » Mon May 13, 2013 12:44 am
..all I want is to be able to print out a good bridge. Wow.
bplemmons
Postby bplemmons » Mon May 13, 2013 1:47 am
http://store.kysanelectronics.com/servl ... -C6/Detail
Is this the right stepper for the extruder upgrade?
thanks
Bill
xnaron
Postby xnaron » Mon May 13, 2013 10:13 am
bplemmons wrote:Wow, that extruder looks amazing. you are really taking the Rostock to a new level..
Bill
All the details are on the first page of this thread ;)
xnaron
Postby xnaron » Mon May 13, 2013 10:14 am
Eaglezsoar wrote:Xnaron: Would it be possible for you to post the squirrel cage fan mounts that you created to hold those squirrel cage fans
you are using?
oops I missed this one in my PM's. The fan mount was from os1r1s. I have asked him to share it. He is going to put it on his github. I will remind him again :) As soon as he does I will link it on the first page.
xnaron
Postby xnaron » Mon May 13, 2013 10:17 am
with bridging it is important that you have your flow rate and nozzle size specified correctly. I always go about 10% higher for nozzle size (extrusion width). So for 0.5mm nozzle I specify it as 0.55mm. Just for fun try setting your extrusion width to 0.7mm and see how that affects your bridging.
Who is online
Users browsing this forum: No registered users and 3 guests
