The Ultimate Rostock Thing Collection
teoman
ULTIMATE 3D JEDDI
Re: The Ultimate Rostock Thing Collection
Post by teoman » Mon Sep 01, 2014 5:27 pm
Does anyone have some stls for some wrenches to adjust the cheapskates?
DavidF
Post by DavidF » Mon Sep 01, 2014 6:08 pm
heres the new J head mount with fan shroud.
http://www.youtube.com/user/aonemarine
Lost pla castings? see me
DavidF
Post by DavidF » Mon Sep 01, 2014 6:09 pm
teoman wrote:Does anyone have some stls for some wrenches to adjust the cheapskates?
Applying mechanical advantage to the cheapskates would not be a good idea. Now a weighted wrench that would apply the right pressure wouldnt be a bad idea....
Kevinvandeusen
Post by Kevinvandeusen » Mon Sep 01, 2014 6:33 pm
wasn't it like 2 5/16" wrenches?
teoman
ULTIMATE 3D JEDDI
Post by teoman » Mon Sep 01, 2014 6:43 pm
That is what the manual says??
DavidF
Post by DavidF » Mon Sep 01, 2014 7:08 pm
That is what the manual says??[/quote
The manual shows the proper adjustment ( how they roll) in the video. Yes they say use a 7/16 wrench to do it. But that is with everything disconnected ie belts and arms.
That's why I suggested a weighted wrench to apply the proper tension. Some may be heavy handed when it comes to adjusting them without being able to slide them up and down. Personally I found it easy to tension them with just my fingers.
teoman
ULTIMATE 3D JEDDI
Post by teoman » Tue Sep 02, 2014 2:07 am
A weighted wrench or a torque wrench would be good.
But as the angle is not fixed maybe a rubber band mechanism would be better.
Lasivian
Post by Lasivian » Fri Jul 29, 2016 10:51 am
Another thing to add to the collection:
http://www.thingiverse.com/thing:1695141
It's a cartridge system for spools since I disliked the wooden arm.
I'm not sure if the V2 uses the same spool holders as my V1 that I built this for tho.
ULTIMATE 3D JEDDI
Post by Xenocrates » Fri Jul 29, 2016 12:53 pm
Looks like a pretty good match for the V2. I have something similar, although it came from someone else, and uses longer cones so that a single set can do more spools, and has a nice big knob on the end. But jeeze, that's a lot of spool holders. how many do you use at once?
Return to “Rostock MAX”
