NEW EZStruder Mounting Kit
General info from SeeMeCNC HQ
PartDaddy
Post by PartDaddy » Fri May 31, 2013 12:03 am
I originaly designed the top plate of the Rostock MAX to allow for top mounted extruders and filament spools. That's why there are holes and notches up there. After I finished design and tooling of the EZStruder, I prototyped this idea just before leaving for the 2013 Bay Area Maker Faire.
I designed the EZStruder mount and filament holder to allow for mounting three units up top. The filament spool arm will hold the small Taulman spools just as well as the larger 2 pound (1kg) spools.
Available for sale now: http://shop.seemecnc.com/EZStruder-Moun ... -70791.htm
Open source files will appear on the RepRap wiki under EZStruder.
Many thanks for your support.
You do not have the required permissions to view the files attached to this post.
~PartDaddy
SeeMeCNC Owner & Founder
Since 1996
Return to “General Announcments”
